需要的可以下载附件
例句: 选择符号并加大(或减小)(如:将rect中小于或等于14mil的PAD加大2mil) #!c:/bin/csh alias DO_INFO 'set IFILE=C:/usr/info.$$;COM info,out_file=$IFILE,write_mode=replace,units=inch,args=\!:*;source $IFILE;rm $IFILE' COM units,type=inch ########################################### DO_INFO -t layer -e $JOB/$STEP/m1-smd -d SYMS_HIST set i = 1 COM display_layer,name=m1-smd,display=yes,number=1 COM work_layer,name=m1-smd while ( $i <= $#gSYMS_HISTsymbol ) if ( `echo $gSYMS_HISTsymbol[$i]| cut -c1-4` =~ "rect" && $gSYMS_HISTsymbol[$i] !~ "0" ) then
set rect_x = `echo $gSYMS_HISTsymbol[$i] | cut -c5- | cut -f1 -d'x'` ----选出“X”之前的数值
set rect_y = `echo $gSYMS_HISTsymbol[$i] | cut -c5- | cut -f2 -d'x'` ----选出“X”之后的数值
set rect_x = ` echo " $rect_x * 1000 / 1 " | bc `
set rect_y = ` echo " $rect_y * 1000 / 1 " | bc `
if ( $rect_x <= 14000 || $rect_y <= 14000 ) then
-----判断句中的数值必须为整数
COM filter_reset,filter_name=popup
COM filter_set,filter_name=popup,update_popup=no,include_syms=$gSYMS_HISTsymbol[$i]
COM filter_area_strt
COM filter_area_end,layer=,filter_name=popup,operation=select,area_type=none,inside_area=no,
intersect_area=no,lines_only=no,ovals_only=no,min_len=0,max_len=0,min_angle=0,max_angle=0
COM sel_copy_other,dest=layer_name,target_layer=2.0,invert=no,dx=0,dy=0,size=2
endif
endif @ i++ end |
