- 5612
楼主 |
发表于 2010-8-21 22:53:41
显示全部楼层
说说Polar Si9000吧。
最近Si9000升级到了10.07,主要更新如下:
Si9000e Changes v10.07 (2010)
New Si Excel Interface:
1. Now licensed to work with Si8000m or Si9000e
2. Delivered with the Si8000m and Si9000e installer
3. Requires new SI_EXCEL licence feature
4. New toolbar option to launch Si Excel Interface
Si9000e Changes v10.06 (2010)
Hatch Plane Support (XFE) Feature:
1. Adjust Lossless Calculation / Sensitivity Analysis results to compensate for the effect of Hatch Planes
2. New Hatch Configuration option provides facilities to define hatch pattern
3. Hatch Plane mode is protected with a separate licence feature (SI_XFE)
4. New Licence Options facility to enable / disable licence features
Parameter Up / Down Options:
1. On the Lossless Calculation tab, when using the up / down arrows the software now only updates W2 when W1 is altered. W2 parameter worked independently.
2. The value in the Lower Trace Width Etch Factor, found under the Configuration | Parameters dialog, is used when calculating the difference between W1 / W2 and G1 / G2
Flexible Beta Structures removed:
1. FlexiCoatedMicrostrip1B
2. FlexiEmbeddedMicrostrip1B2A
3. FlexiOffsetStripline1B2A
一个是对si9000增加了excel接口,这个以前只在si8000里没有,另一个是网格地的特征阻抗计算。
当选中网格地后,计算得到的特征阻抗会偏高,因为网格地的传输线电容减小了。 |
