- 4729
A5:在PROTEL DXP 中,PCB的设计规则有两个主要的变化,定义设计规则范围的方法和用户自定义这个规则的优先权。
在DXP中,设计规则范围是由询问写出的,询问是定义一系列指定元件的字符串文字。
当你在DXP中增加一个新的规则时,它自动地为那种类型的规则分配最高级。如果要设制PCB规则的优先级和限制编辑器,请选择左边树形目
录上的TYPE,显示所有规则(例如安全间距),然后按对话框下面的PRIORITY。
为了证实规则范围已被正确定义,在PCB的进行设计规则的预览,然后点LIST 中选择规则。
There are 2 main changes to design rules in Protel DXP, the way the rule scope is defined, and the fact that the
rule priority is user defined.
In Protel DXP rules are scoped by writing what is called a query. A query is a text string that defines the set
of targeted objects. For more information on queries refer to Item 3431.
When you add a new rule in DXP it is automatically assigned the highest priority for rules of that kind. To set
the priority in the PCB Rules and Constraints Editor, select the rule Type in the tree on the left to display all
rules of that kind (Clearance for example), then click the Priority button at the bottom of the dialog.
The highest priority rule has a priority value of 1.
To confirm that a rule scope has been defined correctly set the PCB Navigator panel to browse by Rules, then
click on a rule in the list. |
