查看: 983|回复: 6
PCB异常急求高手指点
发表于 2010-2-5 13:12:00 | 显示全部楼层 |阅读模式
PCB异常急求高手指点
我们是专业做PCB主板子,现在遇到很麻烦的问题,请各位大侠指点:
我们的主板(表面处理为:OSP)在SMT做成成品后,组装成整机(电脑)到市场,结果在最终用户端用户些时间后出现OPEN,SMT厂要求我们分钟,当取板回来了分析发现在不是处有结晶,类似铜绿(如图),我们最终分析为上件后助焊剂残留经过了段时间线路被咬蚀从而形成开路,可SMT厂确说是PCB的问题。可是线宽、铜厚都符合客户规范。请高手帮忙分析一下,这到底是什么原因产生的?
                         跪谢!!!!!
[此贴子已经被作者于2010-2-5 13:13:03编辑过]
发表于 2010-2-5 13:16:00 | 显示全部楼层
也想多学习点品质方面的知识。
发表于 2010-2-6 14:09:00 | 显示全部楼层
都已經看到不良點位了,剩下只是分析方法,
小心的用剝洋蔥方式,每一次前後留紀錄,照片等,取下樣找廠商打SEM、EDX,同時打懷疑物品的空白組EDX
這種污染造成的,量不會很多,和客戶好好配合,可以溝通的
发表于 2010-2-6 23:18:00 | 显示全部楼层
Wedding Gown Tips
Bustles. One of the first things we think about as we study the styles and designs of wedding gowns is that it should look beautiful both during the ceremony and during the reception. After the ceremony, the bride usually wants to be able to move more freely, be able to turn easily, and perhaps be able to dance. If a gown has a detachable train, this is easily achieved.  But if you’re drawn to gowns without detachable trains, bustling the gown or the train is the answer. cheap bridal gownscheap Wedding dressesbridal gownsWedding GownsWedding GownsMother of bride dressesFlower Girl DressesFlower Girl Dressesglovebridemaid dressgloveProm DressWedding Gownscheap Wedding dresseswedding dresswedding dressesMother of bride dressesbridemaid dress2010 bridemaids dressescheap wedding dresses
Sewing a wedding gown can be one of the most exciting projects you’ll ever undertake, regardless of whether it’s for yourself, for your daughter, or for a friend. Some people sew one, and after it’s finished, can’t wait for the next opportunity to sew another. Other people find themselves involved in a much bigger project than they’d ever anticipated and feel slightly (or totally!) overwhelmed until the last stitch is put in.
Whether you’re tackling your first wedding gown or have sewn several, the tips below will help you avoid some wedding-dress dilemmas so that your sewing experience is enjoyable. Read on and let your imagination help you create a dream-come-true wedding gown.
Wedding Gown Tips
发表于 2011-1-24 21:53:03 | 显示全部楼层
这问题确实少见啊,不过在离子残留的情况下,加上电流的帮助,是很有可能将线路腐蚀断的,就像贾凡尼效应或者原电池反应一样。个人观点!
发表于 2011-1-25 22:29:35 | 显示全部楼层
层压线路注意!
发表于 2011-2-14 23:21:10 | 显示全部楼层
非常奇怪的问题,的确是有点罕见啊
GMT+8, 2025-5-19 00:44 , Processed in 0.130548 second(s), 20 queries .
