- 223
发表于 2010-7-1 14:14:09
显示全部楼层
自己看着改下~~
set codex = `echo "scale=5;($gSR_LIMITSxmax - 2.8 )/1"|bc`
set codey = `echo "scale=5;($gSR_LIMITSymin - 0.312 )/1"|bc`
VOF
COM delete_layer,layer=code
VON
COM create_layer,layer=code,context=misc,type=signal,polarity=positive,\
ins_layer=drill
COM clear_layers
COM affected_layer,mode=all,affected=no
COM display_layer,name=code,display=yes,number=1
COM work_layer,name=code
COM sel_delete
COM add_text,attributes=no,type=canned_text,x=$codex,y=$codey,\
text=$JOB,x_size=0.166,y_size=0.232,w_factor=2.2999999523,polarity=positive,\
angle=0,mirror=no,fontname=canned_57,bar_type=UPC39,bar_char_set=full_ascii,\
bar_checksum=no,bar_background=no,bar_add_string=no,bar_add_string_pos=top,\
bar_width=0.008,bar_height=0.175,ver=1
COM sel_break
COM sel_clear_feat
COM filter_area_strt
COM filter_area_xy,x=$gPROF_LIMITSxmin,y=$gPROF_LIMITSymin
COM filter_area_xy,x=$gPROF_LIMITSxmax,y=$gPROF_LIMITSymax
COM filter_area_end,layer=,filter_name=popup,operation=select,\
area_type=rectangle,inside_area=yes,intersect_area=no,lines_only=no,\
ovals_only=no,min_len=0,max_len=0,min_angle=0,max_angle=0
COM sel_delete_atr,attributes=.nomenclature\;.canned_text\;.drill
COM sel_change_sym,symbol=r$boardcode,reset_angle=no
COM sel_line2pad
COM sel_copy_other,dest=layer_name,target_layer=drill,invert=no,\
dx=0,dy=0,size=0
COM delete_layer,layer=code |
