- 1153
楼主 |
发表于 2003-6-11 10:07:00
显示全部楼层
我又试 了一次,提示“Text prep teminated,see log file.w-padstack s3via_1 not found.referenced from default conatrain set."
log fle 如下:
Pin type restricted to 'ANY POINT'.
Minimum pad dimension is : 35.000
Test pad grid: X: 0.000 Y: 0.000
Minimum test point spacing is : 70.000
Test points allowed under components.
Bare board switch off, no test points allowed on
component pins on tested side.
Tested one pin per net.
Tested unused pins.
Testing allowed directly on pin.
Automatic test point insertion enabled.
Test pad displacement: Min: 5.000, Max: 600.000
Via Replacement Allowed.
Test Pad: BOTTOMTESTVIA
Test Via: VIATEST
Executed in ABSOLUTE mode.
Probe text angle: 0 degrees.
Probe text offset: X: 0.000 Y: 0.500
NOTE: '*' in col 1 indicates that net lacked a true probe hole.
One was randomly selected.
NET PIN PROBE TEXT
Router failed, see tprouter.
Test Prep terminated, error: -289 |
