查看: 683|回复: 4
关于库修改的问题?
发表于 2003-12-3 13:31:15 | 显示全部楼层 |阅读模式
发表于 2003-12-3 13:46:10 | 显示全部楼层
以下是引用mmxmmx在2003-12-3 13:31:15的发言:
1,如何更改参考点的位置,逻辑封装和物理封装修改中?
2,我做了一个600 pin LBGA的器件逻辑封装,和物理封装,制作逻辑封装有简便办法吗?太累了
do you mean the origin point of the footprint?
If so, open your .dra file, and then set the point which you want to be origin point as (0,0). And generate symbol again.[em11]
发表于 2003-12-3 16:22:38 | 显示全部楼层
可以用向导嘛!
发表于 2003-12-3 16:51:08 | 显示全部楼层
first you must confirm the point you want to set to be new origin, and the you can modify the origin in DRA by following the way" setup---drawing parameters--move origin", then imput the location of the point you want to set .
 楼主| 发表于 2003-12-9 13:39:10 | 显示全部楼层
3ks
GMT+8, 2025-5-16 11:20 , Processed in 0.137999 second(s), 20 queries .
