查看: 1104|回复: 0
[求助]【紧急】OrCAD原理图,只要删除某一些网络,就会报错,这是什么原因?
发表于 2009-9-11 15:39:00 | 显示全部楼层 |阅读模式
报错提示如下:而且就这一个错误,这是什么原因呢?
软件是OrCAD+Allegro 15.7 s007,如果用Cadence 16.0则没此问题。
------ Summary Statistics ------
#1 ERROR(102) Run stopped because errors were detected
netrev run on Sep 11 15:29:24 2009
   DESIGN NAME : '01'
   PACKAGING ON May 28 2006 22:05:31
   COMPILE 'logic'
   CHECK_PIN_NAMES OFF
   CROSS_REFERENCE OFF
   FEEDBACK OFF
   INCREMENTAL OFF
   INTERFACE_TYPE PHYSICAL
   MAX_ERRORS 500
   MERGE_MINIMUM 5
   NET_NAME_CHARS '#%&()*+-./:=>?@[]^_`|'
   NET_NAME_LENGTH 24
   OVERSIGHTS ON
   REPLACE_CHECK OFF
   SINGLE_NODE_NETS ON
   SPLIT_MINIMUM 0
   SUPPRESS   20
   WARNINGS ON
 1 error detected
 No oversight detected
 No warning detected
cpu time      4:06:47
elapsed time  0:02:27
GMT+8, 2024-6-19 05:21 , Processed in 0.137223 second(s), 19 queries .
