查看: 876|回复: 2
IPC-2581-2007 制造描述数据和转换方法的印制板装配产品的一般要求
发表于 2011-1-21 11:16:29 | 显示全部楼层 |阅读模式
IPC-2581
with Amendment 1
Generic Requirements for
Printed Board Assembly
Products Manufacturing
Description Data and
Transfer Methodology
Developed by the CAD/CAM Convergence Subcommittee (2-17) of the
Data Generation and Transfer Committee (2-10) of IPC
Users of this publication are encouraged to participate in the
development of future revisions.
Contact:
IPC
3000 Lakeside Drive, Suite 309S
Bannockburn, Illinois
60015-1249
Tel 847 615.7100
Fax 847 615.7105
Generic Requirements for Printed Board Assembly Products
Manufacturing Description Data and Transfer Methodology
1 SCOPE
This standard specifies the XML schema that represents the intelligent data file format used to describe
printed board and printed board assembly products with details sufficient for tooling, manufacturing,
assembly, and inspection requirements. This format may be used for transmitting information between
a printed board designer and a manufacturing or assembly facility. The data is most useful when the
manufacturing cycle includes computer-aided processes and numerical control machines.
The data can be defined in either English or International System of Units (SI) units. The format is a
convergence of the IPC-2511 “GenCAM” and the Valor Computerized Systems “ODB-X” format
structure.
1.1 Focus and intent
The generic format requirements are provided in a series of standards focused on printed board
manufacturing, assembly, and inspection testing. This standard series consists of a generic standard
(IPC-2581) that contains all the general requirements. There are seven sectional standards that are
focused on the XML details necessary to accumulate information in the single file, that addresses the
needs of the manufacturing disciplines producing a particular product.
The sectional standards (IPC-2582 through 2588) paraphrase the important requirements and provide
suggested usage and examples for the topic covered by the sectional standard.
IPC-2581-2007 制造描述数据和转换方法的印制板装配产品的一般要求.pdf
发表于 2011-7-21 09:27:37 | 显示全部楼层
非常感谢。。
发表于 2011-9-21 09:06:41 | 显示全部楼层
顶一下,好东西
GMT+8, 2025-5-18 14:48 , Processed in 0.118324 second(s), 19 queries .
