查看: 1243|回复: 4
[求助]请问OrCAD 10.3有什么新功能吗???
发表于 2005-2-15 07:38:01 | 显示全部楼层 |阅读模式
发表于 2005-2-15 09:30:09 | 显示全部楼层
What’s New in OrCAD Capture 10.3 . . .
New Features and Enhancements . . . . . . . . . . . . . . . . . .
Split Symbol Generation . . . . . . . . . . . . . . . . . . . . . . .
Signal Property Flow . . . . . . . . . . . . . . . . . . . . . . . . .
Page Navigation . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Replace Cache with Preserve Reference Designator
Selection Filter . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Support for Latest Xilinx and Altera File Format . . . . .
List of Important PCRs Fixed . . . . . . . . . . . . . . . . . . . . . .
发表于 2005-2-15 09:34:44 | 显示全部楼层
What’s New in OrCAD Capture CIS 10.3
New Features and Enhancements OrCAD Capture CIS 10.3 brings you the following new features and enhancements:  Support for Version 10.0 of Crystal Reports
Support for Version 10.0 of Crystal Reports Now, Capture CIS provides the redistributable runtime of Crystal Reports 10.0 for Bill of Materials.
List of Important PCRs Fixed Some of the important PCRs addressed in OrCAD 10.3 are listed below:
PCR No Description 723129 The ICA field is not visible in the CIS Configuration Wizard. When you run the CIS wizard to include ICA properties for searching or adding components from Activeparts, the ICA properties may not appear in the ICA field. 721568 The Block column appears blank in Crystal Report. 720380 Library gets locked while placing database parts in a design. 717856 Capture CIS crashes in Windows XP (SP1) while browsing the Part Manager. 716519 Capture consumes significant memory when a hierarchical design with the Implementation path as a Design file is opened. 715324 CIS BOM is not including custom properties in reports. 683949 The 'Please don't Show This Dialog Again' option is not working in the UNDO/ REDO removal confirmation dialog box. This dialog box appears while updating All Part status in CIS Part Manager. 664993 A flat design changes to the Occurrence mode when you run the Update All command from the Part Manager. 653599 The Part Preview window displays vertical pins on the corner of the Part Boundary box as horizontal pins. 604269 The Link Database Part command from the Part Manager does not retain hidden columns. You can reorder or hide columns in CIS Explorer window. If you run the Place Database Part command or the Link Database Part command from a schematic page, the hidden columns are not shown and the new column order is maintained. If you run the Link Database Part command from the Part Manager, CIS Explorers displays all columns. 571456 The the Link Database Part command does not work for different schematic symbols.
发表于 2005-2-17 21:00:13 | 显示全部楼层
COPY AND COPY
发表于 2005-2-24 20:31:11 | 显示全部楼层
谢谢!学了不少。请教:不论Orcad10.0还是Orcad10.3 它们例子中的FPGA都运行不了。而Orcad9.1是可以的。如何解决。
GMT+8, 2025-5-16 11:25 , Processed in 0.121637 second(s), 19 queries .
