楼主: zloveyour
[原创]手把手教你改Pads Layout(PowerPCB)的快捷键
发表于 2006-5-13 17:56:00 | 显示全部楼层
ding
发表于 2006-5-13 19:16:00 | 显示全部楼层
[em01]
发表于 2006-5-13 19:42:00 | 显示全部楼层
号,我要看
发表于 2006-5-24 13:47:00 | 显示全部楼层
好,顶上去
发表于 2006-5-25 12:57:00 | 显示全部楼层
好东西,谢了
发表于 2006-5-25 19:50:00 | 显示全部楼层
可以看看.比比现在自己的快捷键.
发表于 2006-5-25 19:59:00 | 显示全部楼层
果然好, 但我现在一般不用powerpcb布线,一般用它自带的布线器.
发表于 2006-5-25 20:28:00 | 显示全部楼层
That like walkin' in the partk,you c'n modify all the short-cut as you want.but i fond out a question ,any body can modify correspond "Add route " short -cut, if you c'n ,tell me ,will you ? thanks a million!
[此贴子已经被作者于2006-5-25 20:35:18编辑过]
 楼主| 发表于 2006-5-25 23:34:00 | 显示全部楼层
QUOTE:
以下是引用梁小如在2006-5-25 20:28:00的发言:
你如果想改Add Route的快捷键必需把Menufile.dat里的F2全部替换掉就可以了,也许你只替换了一个所以没有成功!
发表于 2006-5-25 23:57:00 | 显示全部楼层
To Zloveyour
   i am here wiht you ,i have replaced all the "F2" by "0" ,but no successful! you arenot follow me ,i mean when i press "0" key to add route ,just through one key "0" to add route
May i have your E-mail ,i send my "menufile.dat" to you ,will you? i am waitin' your hear back
short-cut                              correspond function
Z                                                    verify design
C                                                      display colors
N                                                        nets
[此贴子已经被作者于2006-5-26 0:03:33编辑过]
GMT+8, 2025-11-1 07:58 , Processed in 0.111737 second(s), 13 queries .
