你录制铺铜的时候可能少录了一段: surface: COM fill_params,type=solid,origin_type=datum,solid_type=surface,\ min_brush=1,use_arcs=yes,symbol=r50,dx=0.1,dy=0.1,break_partial=yes,\ cut_prims=no,outline_draw=no,outline_width=0,outline_invert=no COM sr_fill,polarity=positive,step_margin_x=0,step_margin_y=0,\ step_max_dist_x=100,step_max_dist_y=100,sr_margin_x=0,sr_margin_y=0,\ sr_max_dist_x=0,sr_max_dist_y=0,nest_sr=yes,consider_feat=no,\ feat_margin=0,consider_drill=no,drill_margin=0,consider_rout=no,\ dest=affected_layers,layer=l2,attributes=no
pattern: COM fill_params,type=pattern,origin_type=datum,solid_type=surface,\ min_brush=1,use_arcs=yes,symbol=r50,dx=0.1,dy=0.1,break_partial=yes,\ cut_prims=no,outline_draw=no,outline_width=0,outline_invert=no COM sr_fill,polarity=positive,step_margin_x=0,step_margin_y=0,\ step_max_dist_x=100,step_max_dist_y=100,sr_margin_x=0,sr_margin_y=0,\ sr_max_dist_x=0,sr_max_dist_y=0,nest_sr=yes,consider_feat=no,\ feat_margin=0,consider_drill=no,drill_margin=0,consider_rout=no,\ dest=affected_layers,layer=l1,attributes=no
