楼主: luluyy
Altium Designer V16.1.10
发表于 2016-6-22 21:06:58 | 显示全部楼层
谢谢,咋下载呀
发表于 2016-6-22 13:40:27 | 显示全部楼层
zfaidz 发表于 2016-6-22 12:38
楼主神速,昨天出的,就crack掉了。
求iso格式的下载地址。。ad网站的release notes:
Version 16.1.10Build: 233 Date: 21 June 2016
12353Fixed an error that occurs if using non-american regional settings for unit aware parameters in cmplib editor.
12306Resolved an issue that prevented to add Mechanical Layers 17-32 to All Plots in ODB++ Setup (BC: 6573).
12230Fixed bug with inability to create a new project when using network path.
12385Restored work of Mouser server for Supplier Search (it requires authorization from now) (BC:6734).
12475Fixed minor UI issues in the Library panel.
12104Draftsman - Fixed bug where PDF by Draftsman was faulty (BC:6606).
12363Draftsman - Added ability to save circles in sheet templates.
12362Draftsman - Fixed bug where documents options are not saved in Document Template (BC:6745).
12303Draftsman - Fixed crash on complex 3D designs while placing assembly view.
12339Draftsman - Resolved an issue where component marked as not fitted was presented on Sectional view.
点评
发布的时间是今天  发表于 2016-6-22 13:46
发表于 2016-6-22 13:19:17 | 显示全部楼层
速度杠杠的!!
发表于 2016-6-22 12:38:08 | 显示全部楼层
楼主神速,昨天出的,就crack掉了。
点评
求iso格式的下载地址。。ad网站的release notes: Version 16.1.10Build: 233 Date: 21 June 2016  详情 回复 发表于 2016-6-22 13:40
是昨天吗?那它怎么是这个呢? Release Date: 2016-06-22  发表于 2016-6-22 13:23
发表于 2016-6-22 10:54:29 | 显示全部楼层
V16.1.10的链接,好像不能下载的。
有其它链接吗?
发表于 2016-6-22 09:16:10 | 显示全部楼层
這也更新太頻繁了,果斷更新
发表于 2016-6-11 12:59:08 | 显示全部楼层
更新的也太快了
楼主你太厉害了
谢谢你
发表于 2016-6-8 23:00:43 | 显示全部楼层
谢谢楼主分享
发表于 2016-6-8 16:37:25 | 显示全部楼层
顶热心的朋友
GMT+8, 2024-5-23 15:34 , Processed in 0.146460 second(s), 15 queries .
