楼主: sandylin
[原创]simple3的使用
发表于 2009-6-22 22:35:58 | 显示全部楼层
沙发 我来顶一下。  传点资料大家分享下 cam350宏命令详解!
<p>捕捉当前层   a=blanklayer!<br>捕捉当前d码 b=blankdcode!<br>设置10号为0.4的圆<br>set_aperture@ 10,"round d:0.4000"<br>update_dcodebar@ </p>
<p>清除多余d码<br>aptable_compress@ <br>update_dcodebar@ <br>update_dcodebar@ <br>update_dcodebar@ <br>back@</p>
<p><br>单一选择菜单</p>
<p>k%=10<br>openform #1,25,10, "挑各类焊盘 2005-1-27 qmz ", character, okcancel<br>addform #1, 0, 0, "★qmz编制 保护版权★",print<br>addform #1, 0, 1, "选择焊盘形状",choice, k%, "1=圆形", "2=矩形", "3=方形", "4=标靶", "5=花环形", "6=自定义", "7=同心圆", "8=多边形", "9=椭圆形", "10=smt pad"<br>displayform #1<br>canceled% = formcancel(1)<br>deleteform #1<br>if canceled% then goto 999</p>
<p>多重选择菜单<br>k%=2<br>openform #1,30,9, "挑各类焊盘 2005-1-28 保护版权 qmz ", character, okcancel<br>addform #1, 15, 0, "★★qmz编制 ★★",print<br>addform #1, 15, 1, "选择模式", choice, k%, "smt pad", "普通模式" <br>addform #1, 0, 0, "1=round", check, a1%<br>addform #1, 0, 1, "2=square", check, a2%<br>addform #1, 0, 2, "3=rectangle", check, a3%<br>addform #1, 0, 3, "4=target", check, a4%<br>addform #1, 0, 4, "5=thermal", check, a5%<br>addform #1, 0, 5, "6=custom", check, a6%<br>addform #1, 0, 6, "7=donut", check, a7%<br>addform #1, 0, 7, "8=octagon", check, a8%<br>addform #1, 0, 8, "9=oblong", check, a9%</p>
<p>displayform #1<br>canceled% = formcancel(1)<br>deleteform #1<br>if canceled% then goto 999</p>
<p>a=blanklayer!                    '设a=空层的id数<br>b=blankdcode!                    '设b=空d码数</p>
<p>edit_layer@ a,1,1,4,0,"wokao"    '增加一新层。a=层id;1=线路颜色;1=焊盘颜色;4=层属性,<br>                                 '0=显示状态;wokao=层名<br>setlayer@ a                      '设a为当前层</p>
<p>edit_aperture@ b,1,0.200,0.200,b,""   '增加一新d码。b=d码号;1=圆形;0.200=x轴大小;<br>                                      '0.200=y轴大小;b=d码号;""=预留一空d码号<br>update_dcodebar@                 '更新d码条<br>add_text@                        '增加文字<br>addtext@ 0,0,time!               '将系统时间写在原点处。0=x轴坐标;0=y轴坐标;time!=系统时间<br>back@                            '命令结束</p>
<p>view_all@                        '显示所有 </p>
<p>a=blanklayer!<br>b=blankdcode!<br>ts$=dbname!            '设当前文件的文件名和路径=ts$<br>ts$=ucase$(ts$)        '将所有字符转换成大写<br>ts1$=mid$(ts$,17)      '从第17位字符开始取完<br>ts$=ts1$               '设取到的字符=ts$<br>tstr1$="^ "+ts$        '字符#</p>
<p>edit_layer@ a,1,1,4,0,"wokao"<br>setlayer@ a</p>
<p>edit_aperture@ b,1,0.200,0.200,b,""<br>update_dcodebar@<br>add_text@<br>addtext@ 0,0,tstr1$<br>back@</p>
<p>view_all@ </p>
<p>a=blanklayer!<br>b=blankdcode!<br>input "请输入生产型号", xh1$            '显示一个输入框,要求输入型号<br>if xh1$="" then goto 100                '如果输入的是空字符传就转到100<br>xh1$=ucase$(xh1$)                       '将输入的字符转换成大写<br>xh$="^ "+xh1$                           '字符#</p>
<p>edit_aperture@ b,1,0.200,0.200,b,""<br>update_dcodebar@<br>add_text@<br>addtext@ 0,0,xh$<br>back@</p>
<p>view_all@</p>
<p>100 end                                 '结束 </p>
<p><br>openform #1, 30, 8, "窗体按钮", character, yesno   '创建窗体,1号窗体,宽30,高8,标题,单位,按钮<br>displayform #1                                     '显示1号窗体</p>
<p><br>下面我们来介绍一下cam350宏里面的按钮:</p>
<p>ok               只有一个按钮“ok”。<br>okcancel         两个按钮“ok”、“cancel”。<br>yesno            两个按钮“yes”、“no”。<br>nextcancel       两个按钮“next”、“cancel”。<br>yesnocancel      三个按钮“yes”、“no”、“cancel”。<br>prevfinish       三个按钮“previous”、“finish”、“cancel”。<br>nextfinish       三个按钮“next”、“finish”、“cancel”。<br>prevnext         三个按钮“previous”、“next”、“cancel”。<br>prevnextfinish   四个按钮“orevious”、“next”、“finish”、“cancel”。</p>
<p><br>messagebox "消息框按钮、图标及返回值","消息框",yesno,n%    '显示消息框,消息内容,标题,按钮和图标,返回值<br>if n% = 6 then end    '如果返回值=6就结束宏</p>
<p><br>按钮和图标</p>
<p>information = ok 按钮和小写字母 i图标<br>warning     = ok 按钮和感叹号图标<br>error       = ok 按钮和停止标记图标<br>okcancel    = ok 和 cancel 按钮,问号图标<br>yesno       = yes 和 no 按钮,问号图标<br>yesnocancel = yes, no, 和 cancel 按钮,问号图标<br>retrycancel = retry 和 cancel 按钮, 问号图标</p>
<p>返回值:</p>
<p>1 ok<br>2 cancel<br>3 abort<br>4 retry<br>5 ignore<br>6 yes<br>7 no</p>
<p><br>'set variables:             '设置变量</p>
<p>label1$ = "this is an eighty character string to be used as a test for the print command."<br>                            '设置label1$的默认字符串</p>
<p>i% = 4                      '设i%的默认值为:4<br>d# = 12345.678              '设d#的默认值为:12345.678<br>s$ = "the quick brown fox"  '设s$的默认字符串为:"the quick brown fox"<br>j% = 1                      '设j%的默认值为:1<br>k% = 2                      '设k%的默认值为:2<br>filename$ = ""              '设filename$为空字符串</p>
<p><br>openform #1, 50, 12, "test form", character, yesnocancel<br>'新建1号窗体,宽50,高12,标题"test form",单位character,按钮yesnocancel</p>
<p>addform #1, 0, 0, "integer:", input, i%, 0 to 10<br>'新增一输入框,距左边0,距顶边0,显示"integer:",输入命令,变量i%,范围0 to 10</p>
<p>addform #1, 0, 1, "real :  ", input, d#<br>'新增一输入框,距左边0,距顶边1,显示"real :  ",输入命令,变量d#</p>
<p>addform #1, 0, 2, "string :", input, s$<br>'新增一输入框,距左边0,距顶边2,显示"string :",输入命令,变量ds$</p>
<p>addform #1, 1, 3, "check:", check, j%<br>'新增一复选框,距左边1,距顶边3,显示"check:",复选命令,j%=1为选中状态</p>
<p>addform #1, 2, 4, "choice", choice, k%, "choice one", "choice two", "choice three"<br>'新增一单选框,距左边2,距顶边4,显示"choice",单选命令,k%=2默认选中第二项,选项……</p>
<p>addform #1, 0, 8, label1$, print<br>'新增一标签,距左边0,距顶边8,标签内容,显示命令</p>
<p>addform #1, 2, 10, "open file", getopenfilename, filename$<br>'新增一打开文件框,距左边2,距顶边10,显示"open file",打开文件命令,filename$默认为空字符串</p>
<p>displayform #1                            '显示1号窗体</p>
<p>if formcancel(1) then goto skipit         '如果按cancel按钮就执行skipit那一行</p>
<p><br>'set strings for print statement:         '将数值转换成字符串<br>i$ = str$(i%)<br>d$ = str$(d#)<br>j$ = str$(j%)<br>k$ = str$(k%)</p>
<p>print "i% = ",i$+cr!+"d# = ",d$+cr!+"s$ = "+quote!+s$+quote!+cr!+"check = ",j$+cr!+"choice = ",k$+cr!+"file = ",filename$<br>                    '显示各项内容</p>
<p><br>skipit:             '标号</p>
<p>deleteform #1       '删除1号窗体</p>
<p>end                 '结束</p>
<p><br>88<br>print_msg "退出宏!"<br>delay 1000<br>end</p>
发表于 2009-7-21 09:09:04 | 显示全部楼层
ok
发表于 2009-7-21 13:47:11 | 显示全部楼层
3Q
lwhgood 该用户已被删除
发表于 2009-7-23 19:32:48 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2009-7-23 20:46:02 | 显示全部楼层
kanaknakankanaknskflanskflnasklf
发表于 2009-7-31 13:33:20 | 显示全部楼层
需要看看
发表于 2009-8-7 15:00:13 | 显示全部楼层
gaga
发表于 2009-8-9 13:38:14 | 显示全部楼层
什么好定下
下了  还是要谢谢楼主啊
发表于 2009-9-20 16:27:42 | 显示全部楼层
[em07]
发表于 2009-9-26 09:17:23 | 显示全部楼层
不错,顶一下!感谢楼主!
GMT+8, 2024-6-8 02:52 , Processed in 0.125001 second(s), 15 queries .
