37299 | Repeated font setting actions were needed to apply properties for multiple text objects. ( BC:13764) |
37517 | The justification of net labels printed to a PDF with Physical Structure is incorrect if the justification is set to Right. ( BC:13190) |
37942 | Smart Edit for a pin designator in a schematic library document does not add the numeric value when using the formula '!+' and there is failure error. |
38680 | Received error during netlist generation. ( BC:13579) |
39340 | The position of the string over the not-fitted component's graphics was not aligned to the center of symbol. ( BC:13856) |
39602 | Project templates containing schematic sheets in the subfolder resulted in invalid messages about duplicate designators and several sheets with the same name. |
40688 | Font settings were not properly displayed if schematic templates with other fonts were used. |
42014 | "Output Sheet Entry" connection was not detected if the violation was set to 'Warning' or 'Error'. |
42728 | Text with a hyperlink does not move from its origin/pointer location using the mouse or keyboard. |
43055 | Incorrect Variant UniqueID values were shown in the Schematic document. |
43088 | Special strings in schematic don't reflect project options parameters ( BC:15754) |
43139 | Some schematic files displayed a blanket as diagonal lines. ( BC:10481) |
43493 | The visibility of the "Comment" Name was not saved after applying changes in the Schematic - Defaults page of the Preferences dialog. |
43574 | The delete command was not available for a Schematic Library sub-part. |
43596 | It was not possible to edit a text object editing if it was selected by the mouse's right-left selection motion. ( BC:15282) |
43603 | The Find Text - Jump to Results did not adhere to the zoom level set on the System - Navigation page of the Preferences dialog. |
43618 | An ECO from a schematic to a PCB added a new part and removed the previously added part on the PCB. ( BC:15182) |
43879 | Text wrapping for a note does not work properly. ( BC:15269) |
43944 | It was not possible to select local schematic templates when the layout customizations were already configured. |
44030 | Improved the Ctrl+F search text tool to find part parameters. |
44112 | Missing BOM variants for multi-part components if the variants were on different sheets of the hierarchical design. |
44259 | When multiple sheet entries were selected, they could not be moved smoothly and precisely. |
44289 | Received an error during ECO if pad designators contained dashes. ( BC:15530) |
44355 | Software froze when closing Altium Designer. |
24505 | Error occurs when generating a PCB 3D Print with a Render Resolution of 300 and 600 DPI. |
40536 | The Board Information Report was not taking hidden nets into account for the 'Routing completion' information. |
41867 | Design Outputs did not export the rotation of pads from the Solder Mask layer for a package correctly. |
42009 | Snapping does not work properly when dragging vias or tracks if the corresponding snap options are enabled in the Properties panel. ( BC:14503) |
42231 | Snapping to the board edge did not function properly. |
42357 | Snapping to arc centers did not function properly. ( BC:5444) |
42358 | Snap points were displayed even though they were disabled in the Guide Manager region of the Properties panel. ( BC:12451) |
42516 | Added the ability to lock 3D Board Regions. ( BC:15248) |
43459 | Added a custom grid for MCAD coordinates. |
43694 | An issue caused text placed on a polygon to not be selectable after the polygon was moved or flipped. |
43698 | An issue caused two pads to appear in the selection window of a PCB Library document although only one was placed. |
43827 | Changing only the visibility of layers showed the document as modified. ( BC:15072) |
43833 | Added the 'Include Miters' option to the Interactive Sliding mode of the Properties panel to treat miters as normal tracks when dragging. |
43864 | "The input value is invalid" warning was shown for the Snap Distance if a Snap Grid value was selected. |
43892 | When rotating components, the rotation of 360 degrees is now displayed as 0 degrees. ( BC:14474) |
43924 | Added hotkeys to control the height of Sawtooth tuning patterns. |
43950 | Added control over dragging a track with or without an attached miter. Press the C shortcut to toggle the Include Miter mode. |
43961 | Pressing 'Tab' in the PCB document resulted in lost symbols. ( BC:10716) |
44001 | Removed the visible gap on the edge between 2 regions with different layers stacks for the Rigid-Flex design. |
44012 | The Direct Connection between a via and a polygon changes to a Thermal Relief connection automatically when the via is connected to a track and is moved. |
44081 | The Layer Stack Manager incorrectly loaded with "Stack Symmetry" disabled and the surface finish layer removed. |
44094 | Added the PCB.Rendering.MultiselectionDrag option in the Advanced Settings dialog to control multi-selection rendering. |
44095 | Masking and Highlighting did not work for trace and via sliding. |
44113 | ODB++ outputs with 'mm' units selected resulted in an incorrectly generated polygon. |
44145 | The PCB was rendered without the solder mask through semi-transparent 3D models if the 3D model was embedded in a component footprint. ( BC:15468) |
44151 | The board cutouts of Embedded Board Arrays were not displayed in 2D View mode. |
44159 | Component layers were not shown correctly in 3D view for the Rigid-Flex design. ( BC:15400) |
44171 | Vias without drill span assignment did not get generated in ODB++ files. |
44207 | "Conductive" and "non-conductive" were misspelled when using Printed Electronics in the Layer Stack Manager. ( BC:15536) |
44226 | The texture was not displayed on the rotated 3D Body in the PCB document. ( BC:15493) |
44231 | A bug in Automatic Loop Removal in presence of partial vias has been fixed. ( BC:15030) |
37306 | Transparent hatched fills are not displayed in exported PDFs. |
38928 | The Undo command only changed one instance rather than all when the "Apply changes to all instances of same BOM item" was enabled in the Board Assembly View mode of the Properties panel. ( BC:13710) |
40419 | Components through hole pads were not displayed on Board Isometric View and 3D bodies were displayed incorrectly. ( BC:8126) |
42611 | Repositioning and modifying the BOM table resulted in the table's removal from the Draftsman document. |
42710 | Error occurs after placing a Layer Stack Legend or Board Fabrication View. |
43004 | Linear Dimension units were sometimes changed from inches to millimeters. ( BC:11134) |
43761 | Graphics on a PDF output were not rendered properly. ( BC:13175) |
43874 | The Draftsman BOM column justification was lost after adding a new column. |
43875 | Unable to edit Ordinate Dimension object properties. ( BC:11760) |
44021 | When a parameter is changed for several callouts at the same time, the location of all callouts are moved to one location. ( BC:14311) |
44424 | The title of the note from the Draftsman template was deleted upon use in the new Draftsman document. ( BC:10034) |
33989 | Error occurred when trying to clone a component in the Explorer panel if the folder's template of the cloned component was deleted. |
42383 | Sorting in ascending/descending order, the display of parameters and units of measure did not work properly in the Explorer panel. ( BC:14822) |
42818 | The BOM and the Manufacturer Part Search panel did not display the same suppliers. |
43209 | Improved the performance speed when using the Manufacturer Part Search panel. |
43260 | Exception error "Member not found" message during save operation when Custom Data Synchronization was installed. |
43668 | The Run Version Control > Compare with Head command did not detect changes. |
43723 | An error would appear when attempting to assign an existing footprint to a newly created component. |
44007 | System performance is slow when generating a BOM to Excel without a template. |
44141 | Improved comment exporting. |
44640 | Hard crash occurred when attempting to save a footprint in the Single Component Editor. ( BC:15599) |
38878 | Excluding Part from Simulation resulted in a "Could not map pin" error message. |
42053 | Added the display of Simulation Results in the Simulation Dashboard panel. |
43279 | The 'temper' variable is now supported in math expressions for LTSPICE models. |
43280 | The 'idtmod' function is now supported in math expressions for LTSPICE models. |
43300 | The delay function is now supported in the Transient Analysis for LTSPICE models. |
43535 | BJT output current plotting in AC analysis is now supported. |
43649 | The settings for additional Group Tolerances in Monte-Carlo analysis have been added to the Advanced Analysis Settings dialog. |
43674 | Added Interval and Period options for Transient Analysis in the Simulation Dashboard panel. |
43991 | Added the 'RnodeToGnd' advanced parameter (used to process the DC path to ground) with a default value of '1e12'. |
44015 | Default values for AC analysis are now used in the Advanced Analysis Settings dialog. |
