楼主: liujianguoone
電鍍fm集錦(求精)
 楼主| 发表于 2006-4-19 09:10:00 | 显示全部楼层
鍍銅子彈孔
[此贴子已经被作者于2006-4-19 9:10:58编辑过]
 楼主| 发表于 2006-4-19 09:11:00 | 显示全部楼层
錫酸蝕
[此贴子已经被作者于2006-4-19 9:11:55编辑过]
 楼主| 发表于 2006-4-19 09:12:00 | 显示全部楼层
鍍銅面粗造
[此贴子已经被作者于2006-4-19 9:13:13编辑过]
 楼主| 发表于 2006-4-19 09:16:00 | 显示全部楼层
本來好好的一份教材,被自己給分開亂七八糟的,圖片太大了,大家交流啊
syvon 版主原來做的孔破的資料就得頂
[em01]
发表于 2006-4-19 10:12:00 | 显示全部楼层
楼主辛苦了,谢谢分享
 楼主| 发表于 2006-4-19 10:20:00 | 显示全部楼层
syvon , 有沒有辦法傳大一點的東西啊,我有一份好的幹膜資料想和大家分享一下!
ps.
還有大家看到好東西要頂的
[em01]
否则以后我全部设定为回复贴的
[em07]
 楼主| 发表于 2006-4-19 10:57:00 | 显示全部楼层
我發不過去的
Delivery Failure Report
Your document: 幹膜資料
was not delivered to: <syvon@163.com>
because: Router: Unable to dispatch message. Size exceeds 10240 KBytes
What should you do?
You can resend the undeliverable document to the recipients listed above by choosing the Resend button or the Resend command on the Actions menu.
Once you have resent the document you may delete this Delivery Failure Report.
If resending the document is not successful you will receive a new failure report.
Unless you receive other Delivery Failure Reports, the document was successfully delivered to all other recipients.
[em06]
发表于 2006-4-19 11:50:00 | 显示全部楼层
用qq传吧
[此贴子已经被作者于2006-4-19 15:30:31编辑过]
 楼主| 发表于 2006-4-19 12:01:00 | 显示全部楼层
版主大哥, 我們單位qq/msn是不允許用的, 我整理一下,發到
幹膜知識那個帖子上吧
发表于 2006-4-19 16:55:00 | 显示全部楼层
kank n
GMT+8, 2024-5-9 08:41 , Processed in 0.130631 second(s), 14 queries .
