查看: 272|回复: 5
如何编辑allegro中的shape
发表于 2003-1-3 22:37:00 | 显示全部楼层 |阅读模式
发表于 2003-1-4 11:19:00 | 显示全部楼层
先直接在shape的范围内布一根线,放置一个过孔等等,不要管drc,然后再对铜箔进行编辑~~~
 楼主| 发表于 2003-1-4 11:44:00 | 显示全部楼层
如何对shape进行编辑哪?是通过edit/shape吗?但是在shape highlight以后我就不知道该怎么办了。
发表于 2003-1-5 12:02:00 | 显示全部楼层
CLICK RIGHT KEY,AND SELECT “DONE”
发表于 2003-1-6 14:15:00 | 显示全部楼层
以下是引用zhengfengfen在2003-1-3 22:37:32的发言:
当shape放置好了之后,但其他的东西却要作一些改动,比如在shape的范围内重新布一根线,放置一个过孔等等,请问如何操作,需要重画shape吗?
谢谢!!!
In allegro, you can select edit-shape, and then choose the shape which you want to edit, and click somewhere else, or click right botton and click done.
Now you can see, that allegro has changed it's menu to shape editing menu. What u have to do, choose void, select autovoid or anything that you want.
发表于 2003-1-13 10:34:00 | 显示全部楼层
先直接在shape的范围内布一根线,放置一个过孔等等,不要管drc,然后再对铜箔进行编辑:edit-shape然后弹出右键选done,然后在菜单中选void(一般用auto就ok了)
GMT+8, 2025-5-16 06:23 , Processed in 0.131437 second(s), 20 queries .
