第一次生成光绘文件 artwork .art 文件的尺寸和板子的尺寸应该是一样的吗? WARNING: database resolution exceeds the resolution of the output coordinates (see FORMAT in parameter file). Some roundoff of coordinates may occur unless the number of decimal places in the output file is increased. WARNING: Photoplot window exceeds film size (2400.00 x 1600.00) stated in parameter file. WARNING: Photoplot window exceeds film size (2400.00 x 1600.00) stated in parameter file.
DEVICE-TYPE GERBER6X00 OUTPUT-UNITS INCHES FILM-SIZE 240000 160000 FORMAT 5.4 如果把fomat 改成5.5就没有第一个警告,但是后两个还有,并且.art的尺寸 是真实的10倍...... 到底该怎么设置啊?大家指点!!! |
