下面就行了,又不是什么好东西,搞那么复杂. zhang1949sz@21cn.com # Filename: N84A0-3406-0000-00AD % Dongle : 84A0-3406-0000-00AD % Customer: Yantat % Date : 050610 # Comment : # anaelsp-9-255-255-255 TRSNJNNE - Electrical spacing analysis analyze-9-255-255-255 NCYITPYB - PCB Analyzer aoi14at-9-255-255-255 DIQLSGFM - Orbotech PC AOI Interface aoinfnx-9-255-255-255 FRYZTDBV - Orbotech InFinex AOI Interface aoispir-9-255-255-255 EHUSIRFM - Orbotech Inspire AOI Interface aoivisn-9-255-255-255 WBMAWJNR - Orbotech Vision AOI Interface aoivsnm-9-255-255-255 MHWWHKYM anasmbl-9-255-255-255 FWADSXZF autodrl-9-255-255-255 OJDHBRWR - Auto Drill Manager autorot-9-255-255-255 DPFZAMWH - Auto Rout Manager camteki-9-255-255-255 MMMCUHBK - CAMTEK AOI Interface cbflows-9-255-255-255 KHDSCPJP - Cyberflows cbforms-9-255-255-255 TQWQBUXU - Cyberforms clnliun-9-255-255-255 GJLVBVGF - Line Unification clnnome-9-255-255-255 ZHBMBMED - Legend Detection clnhtch-9-255-255-255 WBQDKWIS - Crosshatch Detection cutdata-9-255-255-255 CFPXCVEH - Cutting Data dfmaaps-9-255-255-255 JQBEXCXH - DFM - Advanced Pad Subst (all angles) dfmacut-9-255-255-255 NDXDCQNL - DFM - Sliver Fill dfmatrd-9-255-255-255 ROFPBCJX - DFM - Advanced Teardrop dfmcbal-9-255-255-255 YQVPCYGQ - DFM - Copper Balancing dfmdenv-9-255-255-255 DZBHXPGU - DFM - DFM Environment dfmecmp-9-255-255-255 KIAEJYKD - DFM - Etch Compensation dfmhmhd-9-255-255-255 QZIOOIWK - DFM - Hammerhead-like etch compensation dfmlopt-9-255-255-255 GJDQEELO - DFM - Line Width Optimizer dfmneck-9-255-255-255 JOQHFKEI - DFM - Neck Down Repair dfmpgop-9-255-255-255 DIRHSQGQ - DFM - P&G Optimization dfmphel-9-255-255-255 YHASWEAY - DFM - Pin Hole Elimination dfmdtcc-9-255-255-255 OUJZKEOY - DFM - Drill to copper count dfmtbgb-9-255-255-255 ZPZFDGOT - DFM - Tie bar generation dfmrlrm-9-255-255-255 VCCFEGXD - DFM - Redundant Vectors Removal dfmsfil-9-255-255-255 HMJPBIVB - DFM - Sliver Filling dfmsigo-9-255-255-255 YDIGQKKR - DFM - Signal Layer Optimizer dfmsmop-9-255-255-255 PTEZTCDJ - DFM - Solder Mask Optimizer dfmspop-9-255-255-255 WEZBJLTN - DFM - Solder Paste Optimization dfmsscl-9-255-255-255 GXDEVGSG - DFM - Silk Screen Optimizer dfmtxts-9-255-255-255 NLHBWZFW - DFM - Sliver Filling dfmlspc-9-255-255-255 IBCVHKPY - DFM - Local Spacing dfmpsop-9-255-255-255 WPAYHAIK - DFM - Parallel Spacing Optimization dfmdetc-9-255-255-255 TIOMRKVQ - DFM - Dynamic Etch Compensation dfmpcop-9-255-255-255 TFSWPRAN - DFM - Positive Plane Optimization dftnpgn-9-255-255-255 NOBTEKET - Net Points Generation dimedit-9-255-255-255 MNPIJJGG - Rout Dimension Editor drlopti-9-255-255-255 QPUBSWCH - Drill Path Optimizer drltmgr-9-255-255-255 TJGEHHAF - Drill Tool Manager edacdif-9-255-255-255 NEPGENOH edacdnc-9-255-255-255 COOQLLVU edamntc-9-255-255-255 HEZOYOMM edamntf-9-255-255-255 ARMNVSOM edapads-9-255-255-255 VLDXQIRI edasync-9-255-255-255 CXDWECMF edaview-9-255-255-255 ROGOOOKR - EDA Viewing edavrml-9-255-255-255 TOCCEFUC enterpr-9-255-255-255 HHWYAZOL equotst-9-255-255-255 EJKEXPHB - e-quote quotation software etmnger-9-255-255-255 UZTBLPPK - Electrical Test manager etltmgr-9-255-255-255 CYIAGVFB - ETM Light ezukeni-9-255-255-255 CUNXHUMV ezukenr-9-255-255-255 FYCIMKDV filmopt-9-255-255-255 TLJCSONA - Film Optimization fltview-9-255-255-255 HJGAHDKD - Fault Viewer frmwork-9-255-255-255 ZSYQZVFH - Framework fwflows-9-255-255-255 PBYHSSQA - Workflows vwforms-9-255-255-255 HOVUTXJG fwforms-9-255-255-255 WMTIOGHP - Workforms geditor-9-255-255-255 RTYSFWAA - Graphic Editor genes40-9-255-255-255 SORGTTBD - Genesis 4.0 genes50-9-255-255-255 ATKIBCRA - Genesis 5.0 genes60-9-255-255-255 UQHZJYTU - Genesis 6.0 genes70-9-255-255-255 IFLANTFX - Genesis 7.0 genes72-9-255-255-255 VBCBNUVG - Genesis 7.2 genes80-9-255-255-255 IRLPXNPZ - Genesis 8.0 genes81-9-255-255-255 MNRQNZEF - Genesis 8.1 genes82-9-255-255-255 PWESVTLP - Genesis 8.2 genes90-9-255-255-255 SDFWMBTG - Genesis 9.0 genesis-9-255-255-255 SKJUQJRT - Genesis genflex-9-255-255-255 ADFDKJBC - GenFlex gviewer-9-255-255-255 ZMNSKCLX - Graphic Viewer impedan-9-255-255-255 RPVAZRJF - Impedance Control inp274d-9-255-255-255 HUKZSGLC - Input - Gerber 274D inp274x-9-255-255-255 RQYJRJBX - Input - Gerber 274X inp356a-9-255-255-255 FOCNLCRK - Input - IPC D-356A inp356d-9-255-255-255 ZESAODKI - Input - IPC-D-356 inpadxf-9-255-255-255 GPALZTTQ - Input - Autocad DXF inpaplt-9-255-255-255 AAVJKKDN - Input - CSI Autoplot inpbdpf-9-255-255-255 QOCDQGCC - Input - Barco DPF inpexci-9-255-255-255 OOZHNUZV - Input - Excellon Image inpexcl-9-255-255-255 ZULPAGCG - Input - Excellon I & II Drill & Rout inphita-9-255-255-255 CDKIONCK - Input - Hitachi inphpgl-9-255-255-255 QCKVDFKS - Input - HPGL I & II inpimag-9-255-255-255 RIMNCDDH - Input - Orbotech inpipar-9-255-255-255 IVGAHIOW - Input - IGI PAR inplesi-9-255-255-255 JOFEQUPY - Input - ESI Laser Drill Format inpment-9-255-255-255 ODJQBMQW - Input - Mentor Netlist inpnpda-9-255-255-255 BWFGMFOG - Input - PDA Router inpodbx-9-255-255-255 SHIFYPLU - Input - ODB++ XML inpopfx-9-255-255-255 TYBXJZTL - Input - OPFX inppads-9-255-255-255 EEMVXNUE - Input - N/A inpposx-9-255-255-255 QIEVRBPE - Input - Posalux Drill inprati-9-255-255-255 GGGIUDDG - Input - ATI Router inpsmdr-9-255-255-255 NPDOSHZF - Input - Sieb & Meyer Drill/Rout inptrud-9-255-255-255 HIBKSUMO - Input - Trudril inpwess-9-255-255-255 MGDRAXWL - Input - Wessel Drill inpbomt-9-255-255-255 STIPRPCJ inpsoli-9-255-255-255 OIINQAUU - Input - from Solio database inptnec-9-255-255-255 WUCSVGFI - Input - NEC kitpack-9-255-255-255 BKRVAGRV - KIT Package localev-9-255-255-255 HXUFZUDL - Foreign Language Support maniaao-9-255-255-255 SBIRINVR - Mania AOI Interface micrchk-9-255-255-255 BVKUCAUM - Microvia checks Analyzer quotchk-9-255-255-255 ARVFGKAD - Quote Analysis netlist-9-255-255-255 KCVUPQOJ - Netlist Analysis netopti-9-255-255-255 VZUOBPEJ - Netlist Optimizer odbcomm-9-255-255-255 GCGAXMUF odbcclt-9-255-255-255 LCCJEBNS - ODB++ Communicator Client odbcsrv-9-255-255-255 VNMRDKLJ - ODB++ Communicator Server onlndrc-9-255-255-255 EKMCZNOZ - Online DRC orcdr14-9-255-255-255 XTIGHFNS - Manual Orbotech PC AOI Interface ous2221-9-255-255-255 CPNRPJWL out274d-9-255-255-255 EJRZWIBH - Output - Gerber 274D out274x-9-255-255-255 SHEDWEMX - Output - Gerber 274X out3070-9-255-255-255 SDDSTHRP outfatf-9-255-255-255 LDMMVKWZ - Output - Fabmaster FATF out356a-9-255-255-255 ODIVUAET - Output - IPC-D-356A out356d-9-255-255-255 CIUFQXIG - Output - IPC-D-356 outadxf-9-255-255-255 ITVMFEXS - Output - Autocad DXF outanfa-9-255-255-255 SILFUDIM - Output - ANF-A series Output (Netlist) outaplt-9-255-255-255 KRJFCDPG - Output - CSI Autoplot outatfe-9-255-255-255 BDXUGHHO - Output - ATF outbdpf-9-255-255-255 FNFRSJCB - Output - Barco DPF outbslr-9-255-255-255 RKRXGKTW - Output - BSL Rieslang outcirc-9-255-255-255 QMNYWBHW - Output - Circuitest outcrtl-9-255-255-255 AJECYNBH - Output - ETM Circuotline outdsrn-9-255-255-255 SVNLKCCY - Output - Output Dai-nippon screen outepcs-9-255-255-255 VOHNOYKN - Output - EPC & ATF Stations outetec-9-255-255-255 TMAXWMGM - Output - ETEC Direct Imager outevct-9-255-255-255 HEDTMRLO - Output - ETM Everett Charles outexci-9-255-255-255 ACYCXEUJ - Output - Excellon Image outexcl-9-255-255-255 OBNXKCIJ - Output - Excellon I&II Drill & Rout outgenc-9-255-255-255 QYMYZQZO - Output - Mitron Gencad outhiok-9-255-255-255 AHBCOCVN - Output - Hioki outhita-9-255-255-255 URQKZLCI - Output - Hitachi outhopf-9-255-255-255 FVGSYHSO - Output - OPF outopfx-9-255-255-255 HUBBKEKG - Output - OPFX (LP 7008) outhpgl-9-255-255-255 NZOKFCYX - Output - HPGL outimag-9-255-255-255 NLSLANSN - Output - Orbotech outintg-9-255-255-255 HPHFKCFD - Output - Integri-Test Netlist outipar-9-255-255-255 WUMZIOFX - Output - IGI PAR outlesi-9-255-255-255 BKMJVSHA - Output - Laser Drill Esi output outlexc-9-255-255-255 CDMFWKVA - Output - Excellon Laser Drill format outlhit-9-255-255-255 IZGEAGPB - Output - Hitachi Laser Drill format outloyd-9-255-255-255 LJBFCGPD - Output - Loyd Doyle AOI output outluml-9-255-255-255 RCYANFLY - Output - Luther & Maelzer UDL file outmani-9-255-255-255 JROASNVI - Output - ETM Mania outmcrf-9-255-255-255 JSGHGKTP - Output - MicroCraft outnecs-9-255-255-255 IUTUOXCQ - Output - NEC Sam Format outnpda-9-255-255-255 MPFMWMSJ - Output - PDA outntdn-9-255-255-255 ORRIKFUT - Output - NTD outodbx-9-255-255-255 GTOCMJNG - Output - ODB++ XML outopfx-9-255-255-255 HUBBKEKG - Output - OPFX (LP 7008) outposx-9-255-255-255 UKHQCKNM - Output - Posalux Drill/Rout outprob-9-255-255-255 NSGTONCT - Output - Probot outpscr-9-255-255-255 SCOPXNVN - Output - Postscript outrace-9-255-255-255 YOPUWHXW - Output - Trace outraid-9-255-255-255 HRUGORBP - Output - RAID for Probot repair station outrati-9-255-255-255 MAUXCVEC - Output - ATI Router outrpdg-9-255-255-255 MGKKFLBH - Output - Gerber RPD outsmdr-9-255-255-255 GPVAYSMB - Output - Sieb & Meyer Drill/Rout outsoli-9-255-255-255 MOYLKTOQ - Output - to Solio database outtifn-9-255-255-255 KWDOOXEI - Output - Tecnost Tif format netlist outtrud-9-255-255-255 DMYZKULX - Output - True Drill outttin-9-255-255-255 CQJPGQAU - Output - TTI format netlist (IPC 4) outwess-9-255-255-255 BOQUAYJM - Output - Wessel Drill/Rout panelop-9-255-255-255 NZVEMYUI - Panel Optimizer plmpack-9-255-255-255 FOHLEPIH scdebug-9-255-255-255 PVVBDEHI - Script Debugger shrlist-9-255-255-255 JDEQDSJJ - Sharelist shroutr-9-255-255-255 HGRSIQVD statist-9-255-255-255 RNXMMOXM stackup-9-255-255-255 ZTOUNGBA - Stackup Builder subpano-9-255-255-255 AOAIMDSC - Sub Panel Optimizer winnt40-9-003-003-255 LTLLRZLI - Windows NT Operating System -----BEGIN SIGNATURE----- Z2jafsqiJUflFMWC2LYowyGxIWkn4BLJWstWSkTxCsfWmyO9rvZd1LS6nYnJA3Fh LRwjkLJHYNrkaAVoni5+0Q== -----END SIGNATURE----- |
