查看: 1829|回复: 12
想請教一下:
发表于 2003-1-21 13:10:00 | 显示全部楼层 |阅读模式
是否有人知道有何方法,可以增加allegro layout 的速度...
就是雙手並用.而不單單只是移動鼠標.或者有何快速且常用的指令...謝謝!!!
[em01]
发表于 2003-1-21 14:40:00 | 显示全部楼层
在commond行下输入alias,会看到很多默认的快捷键,还可以自己增加和更改。
 楼主| 发表于 2003-1-21 14:54:00 | 显示全部楼层
感謝板主題供!在冒昧請問板主.是否有常用的command資料.謝謝!
发表于 2003-1-21 15:42:00 | 显示全部楼层
那里只能显示吗??如果要改该到哪里改呢??
 楼主| 发表于 2003-1-21 16:15:00 | 显示全部楼层
若要改要到Cadence\share\pcb\text內的env檔.裡的
# NEW STYLE FUNCTION KEY ALIASES
# F1 is normally reserved by the system for Help so we don't use it
alias F2 done
alias F3 oops
alias F4 cancel
alias F5 show element
alias F6 property net
alias F7 vertex
alias F8 zoom points
alias F9  zoom fit
alias F10 zoom in
alias F11 zoom out
alias F12 property refdes
alias Home zoom fit
alias Pgup zoom in
alias Pgdown zoom out
alias End zoom points
alias Del delete
alias SF1 add connect
alias SF2 grid
alias SF3 hilight pick
alias SF4 dehilight all
alias SF5 redisplay
alias SF6 slide
alias SF7 move
alias SF9 save_as temp
alias ~N new
alias ~O open
alias ~S save
发表于 2003-1-21 18:20:00 | 显示全部楼层
“內的env檔.裡的”为何我没有看见那个ENV档呢????????
 楼主| 发表于 2003-1-21 18:31:00 | 显示全部楼层
應該會有.我是用 ALLEGRO13.6
发表于 2003-1-22 22:39:00 | 显示全部楼层
env指的是一个文本文件。
发表于 2003-1-24 13:44:00 | 显示全部楼层
我怎么看到的是如下的东东呢?
# ALLEGRO GLOBAL Environment file
# $Header: env,v 1.153 99/03/26 15:24:26 lalit $
# System Variables
set GLOBAL = $ALLEGRO_INSTALL_DIR/text
# change from LIBPATH because it conflicts with IBM's shared library
# environment variable
set ALIBPATH = $ALLEGRO_INSTALL_DIR/pcb_lib
set COMPLIBPATH = $ALLEGRO_INSTALL_DIR/allegrolib
set GLOBALPATH = . $GLOBAL
# Allegro Data Services Variable
set ADSPATH = $GLOBALPATH
# Configuration variables (Don't change)
set FORMPATH = . $GLOBAL/forms
set MENU  = $GLOBAL/cuimenus
set MENUPATH = . $MENU
set UNITS = $GLOBAL/units.dat
set BMPPATH = . $GLOBAL/icons
set RESOURCE = resource
# SigNoise data installation directory
set SIGNAL_INSTALL_DIR = $ALLEGRO_INSTALL_DIR/signal
set SIGNAL_OPTLIB_DIR = $SIGNAL_INSTALL_DIR/optlib
set SIGNOISEPATH = . $LOCALENV $SIGNAL_INSTALL_DIR $SIGNAL_OPTLIB_DIR $GLOBAL
# System Design Link .sdl file search path
set SDLPATH = . sdls .. ../sdls
# Thermax data installation directory
set THERMAX_INSTALL_DIR =  $ALLEGRO_INSTALL_DIR/thermal
# Drawing font
set VECTORFONTPATH = . $GLOBAL
set ANSIFONT = ansifont
set KANJIFONTPATH = . $GLOBAL/fonts/kanji
set KANJIFONT1 = kanjifont1
set KANJIFONT2 = kanjifont2
# Display Variable
# would disable fat lines in arc move dynamics
#set display_nodynamicarcwidth
# disable repair under ratsnests
set display_norepair rats
set display_shapefill_analysis 1
# disable dragging for popup selection to get strokes on the right button
#set no_dragpopup
# Library Search Path Variables
set PSMPATH = . symbols .. ../symbols $ALIBPATH/symbols $COMPLIBPATH/symbols
set PADPATH = . symbols .. ../symbols $ALIBPATH/symbols $COMPLIBPATH/symbols
set DEVPATH = . devices .. ../devices $ALIBPATH/devices $COMPLIBPATH/devices
set ARTPATH = . ..
set APTPATH = . ..
set NCDPATH = . .. $GLOBAL/nclegend
set TEXTPATH = . $GLOBAL/views
set TMXBNDPATH = . .. $GLOBAL/thermal
set TMXLIBPATH = . .. $GLOBAL/thermal
set TMXDATPATH = . .. $GLOBAL/thermal
set TMXSYMPATH = . $ALIBPATH/symbols $COMPLIBPATH/symbols $THERMAX_INSTALL_DIR/symbols
set tmxreflib = basicpcb
set HELPPATH = . $ALLEGRO_INSTALL_DIR/help $GLOBAL/help
set DFAAUDITPATH = . $ALLEGRO_INSTALL_DIR/assembly
set SCRIPTPATH = . $GLOBAL/script
set TECHPATH = . $GLOBAL/tech
set CLIPPATH = .
set MODULEPATH = .
set TOPOLOGY_TEMPLATE_PATH = . templates .. ../templates $ALIBPATH/templates $COMPLIBPATH/templates
set XTALK_TABLE_PATH = . xtalk_tables .. ../xtalk_tables $ALIBPATH/xtalk_tables
# Graphics demo env
set IMAGEPATH = $ALLEGRO_INSTALL_DIR/examples/image
# Aliases
# Bind roam operations to function keys
set roamInc = 96
alias Up        roam y -$roamInc
alias Down      roam y $roamInc
alias Left      roam x -$roamInc
alias Right     roam x $roamInc
alias F2 done
alias F3 oops
alias F4 cancel
alias F6 property nets
alias F7 vertex
alias F9 zoom fit
alias F10 zoom in
alias F11 zoom out
alias SF2 grid
alias SF5 redisplay
alias SF6 slide
alias SF7 move
alias ~N new
alias ~O open
alias ~S save
# OTHER ALIASES
alias edps padedit
alias rps "replace padstack"
alias unplrp report unplaced
alias x pick
alias y picky
alias ix ipick
alias iy ipicky
# autoroam
alias sar set pcb_autoroam
alias uar unset pcb_autoroam
# COMMAND DEFAULTS
# allow slide to work on arcs by default
set slide_arcs
# Compatibility aliases
alias window        zoom
alias hilite        hilight
alias dehilite        dehilight
是不是我们公司修改了什么东西呢?
不过COMMAND>ALIAS到可以看到这个相同的内容
发表于 2003-1-24 13:45:00 | 显示全部楼层
我好傻呀!见笑了,呵呵。。
GMT+8, 2025-5-16 04:07 , Processed in 0.128454 second(s), 19 queries .
