"Backspace" key Data Cancel "Return" key Command End "Space" key Data End "Escape" key Command Cancel "r" key Redo "u" key Undo "n" key Next "1" key, "s" key Redraw "0" key, "w" key Entire Sheet "8" key, "Up ARROW" key an upward "2" key, "Down ARROW" key an downward "6" key, "Right ARROW" key an rightward "4" key, "Left ARROW" key an leftward "+" key Zoom Out "-" key Zoom In "7" key, "z" key Zoom Area "9" key, "j" key Adjust "g" key Toggle grid display ON or OFF "t" key Snap to Grid ON or OFF "r" key Rotate object "m" key Mirror object "d" key Detach object "h" key Horizontal Lock "v" key Vertical Lock "f" key Unlock object "i" key Display Contents "a" key lace object in arc mode "c" key Auto connect object pin "Shift" key+"Up ARROW" key Moves the object up a small distance "Shift" key+"Down ARROW" key Moves the object down a small distance "Shift" key+"Right ARROW" key Moves the object a small distance right "Shift" key+"Left ARROW" key Moves the object a small distance left "Ctrl" key+"o" key Open "Ctrl" key+"s" key Save "Ctrl" key+"a" key Save as "Ctrl" key+"p" key rint "Ctrl" key+"q" key Exit "Ctrl" key+"e" key Delete "Ctrl" key+"x" key Cut "Ctrl" key+"c" key Copy "Ctrl" key+"m" key Move "Ctrl" key+"d" key Duplicate "Ctrl" key+"v" key aste "Ctrl" key+"t" key Stretch "Ctrl" key+"h" key Reshape "Ctrl" key+"w" key lace net 以上是系统自带的,若要自定义快捷键,请在Key-map里自行设定。 |
