如图所示,本来是已经避开的,但还是有DRC 显示,必须一一去动下
下面是drc信息,为什么会有0.01的差距?我格点是设置为1 LISTING: 1 element(s) < DRC ERROR > Class: DRC ERROR CLASS Subclass: BOTTOM Origin xy: (2391.00 1048.00) CONSTRAINT: Shape to Thru Via Spacing CONSTRAINT SET: DEFAULT CONSTRAINT TYPE: NET SPACING CONSTRAINTS Constraint value: 7 MIL Actual value: 6.99 MIL - - - - - - - - - - - - - - - - - - - - Element type: SHAPE Class: ETCH Subclass: BOTTOM Part of Net Name: AGND - - - - - - - - - - - - - - - - - - - - Element type: VIA Class: VIA CLASS origin-xy: (2391.00 1036.00) part of net name: VCM number of connected lines: 2 padstack name: VIA24D12 padstack defined from TOP to BOTTOM rotation: 0.000 degrees via is not mirrored - - - - - - - - - - - - - - - - - - - -
