查看: 1335|回复: 3
脚本修改尾孔顺序
发表于 2007-2-8 16:17:00 | 显示全部楼层 |阅读模式
请问各位大佬:
我原来所在公司须将字符孔(0.55MM)的刀序排到最后
我打算通过将其在AUTO DRILL MANAGER中将其字符孔的STAGE设为3后再修改下面这段程式来达到目的(下面这段只能将SLOT孔与钻孔分开来排),我如何修改这段程式保证钻带(在有槽孔的时候)将字符孔提出来排到最后
且在没有槽孔的时候也不会冲突了?
if ( $slotyn == "2" ) then
     PAUSE Please check slot and drll table
     source $GENESIS_DIR/sys/scripts/program/gui_set2
     gui_out FORM
     guiout LABEL Please Enter Hole num:
     guiout ENDFORM
     gui_out FORM
     guiout LABEL HoleNum
     guiout TEXT holenum 3
     guiout ENDFORM
     gui_out FORM
     guiout LABEL SlotNum
     guiout TEXT slotnum 3
     guiout ENDFORM
     guiout CLABEL Execute
     dogui
     set holetmp = `echo "scale = 1; $holenum + 2" | bc`
     set holetmp1 = `echo "scale = 1; $holenum + 3" | bc`
     set slottmp = `echo "scale = 1; $slotnum + 2" | bc`
     set slottmp1 = `echo "scale = 1; $slotnum + 4" | bc`
     set i = 1
     set n = 1
     sed -n 1,"$holetmp"p d:/disk/film/$JOB/$JOB.out > d:/disk/film/$JOB/$JOB.drlhead
     while ( $i <= $slotnum )
           set tempnum = `echo "scale = 1; $holenum + $i" | bc`
        if ( $tempnum < 10 ) then
           sed s/T0"$i"/T0"$tempnum"/g d:/disk/film/$JOB/$JOB.slot > d:/disk/film/$JOB/$JOB.slotnew
        else
           sed s/T0"$i"/T"$tempnum"/g d:/disk/film/$JOB/$JOB.slot > d:/disk/film/$JOB/$JOB.slotnew
        endif
        @ i++
        mv d:/disk/film/$JOB/$JOB.slotnew d:/disk/film/$JOB/$JOB.slot
     end
     sed -n 3,"$slottmp"p d:/disk/film/$JOB/$JOB.slot > d:/disk/film/$JOB/$JOB.slothead
     cat d:/disk/film/$JOB/$JOB.slothead >> d:/disk/film/$JOB/$JOB.drlhead
     sed /M30/d d:/disk/film/$JOB/$JOB.out > d:/disk/film/$JOB/$JOB.drll
     sed -n "$holetmp1",\$p d:/disk/film/$JOB/$JOB.drll > d:/disk/film/$JOB/$JOB.drlbody
     sed -n "$slottmp1",\$p d:/disk/film/$JOB/$JOB.slot > d:/disk/film/$JOB/$JOB.slotbody
     cat d:/disk/film/$JOB/$JOB.drlhead > d:/disk/film/$JOB/$JOB.out
     cat d:/disk/film/$JOB/$JOB.drlbody >> d:/disk/film/$JOB/$JOB.out
     cat d:/disk/film/$JOB/$JOB.slotbody >> d:/disk/film/$JOB/$JOB.out
     rm -r d:/disk/film/$JOB/$JOB.drlbody
     rm -r d:/disk/film/$JOB/$JOB.drlhead
     rm -r d:/disk/film/$JOB/$JOB.drll
     rm -r d:/disk/film/$JOB/$JOB.slot
     rm -r d:/disk/film/$JOB/$JOB.slotbody
     rm -r d:/disk/film/$JOB/$JOB.slothead
     rm -r d:/disk/film/$JOB/$JOB.rep
     rm -r d:/disk/film/$JOB/$JOB.slotrep
     PAUSE Thank you,Please check drl
     COM ncset_page_close
else
     PAUSE Thank you,Please check out
endif
 楼主| 发表于 2007-2-15 18:24:00 | 显示全部楼层
呵呵
我已修改OK了,只不过槽孔不能超过10把刀
不过我不会修改SET_TABLE文件将其字符孔自动设成STAGE 3
发表于 2007-2-28 18:01:00 | 显示全部楼层
24580968QQ 联系我 给你一个简单的脚本
 楼主| 发表于 2007-3-4 20:31:00 | 显示全部楼层
这个脚本我可以搞定了
但是没有办法将字符孔的属性在SET_TABLE文件中将其自动设为STAGE 3(有SLOT孔时);没有SLOT孔时设为STAGE 2  IF语名好像不太可能实现这个功能
GMT+8, 2024-5-12 21:10 , Processed in 0.132624 second(s), 18 queries .
