查看: 1774|回复: 1
Si9000e
发表于 2007-4-16 21:53:00 | 显示全部楼层 |阅读模式
Si9000e Changes v7.10
Export W-Element HSPICE Format
Increase 3 decimal point precision on scientific notation for Copy to Clipboard functions
Change default S-Parameter Steps to 200
Add Glossary to Help menu
Append /line to column headers, graph axis and Copy to Clipboard format when Result Presentation is /Length of Line
Following feedback regarding our Kf / FEXT result, make code changes to calculation function
Add units to Kf on Crosstalk tab
FEXT has a maximum limit value Vf=0.5Vin
Correct Copy to Clipboard functions: to work correctly with Singled Ended SPICE RLGC and Differential Even Mode tabs
Correct Touchstone output format
Alter graph source data when using Differential mode for Inductance, Resistance, Capacitance and Conductance
Suppress differential mode graph option when plotting S-Parameter data
Correct Edge Coupled Embedded Microstrip 1E1B2A structure
Correct Goal Seeker for W1 / W2 (etch factor orientation) when using 1E structures
Er==1 sometimes results in infinity errors. Alter Calc Engine error handler
Si9000e Changes v7.00
Near end and far end crosstalk coefficients, Kb, Kf and FEXT now displayed within interface on separate tab for differential structures (symmetrical / 2 trace structures)
Interpolate S-Parameters to speed calculation times.  Separate S-Parameter Frequency Steps parameter entry provides this functionality
Line Length now matches units of lossless parameters
New Results Presentation options allows the display of results / graph per Line Length, per inch or per Metre.
Four new structures introduced.  Edge Coupled Offset Stripline 1B2A1R, Edge Coupled Embedded Microstrip 1B2A1R, Embedded Microstrip 1E1B1A and Edge Coupled Embedded Microstrip 1E1B1A
New Goal Seek Constant Pitch option.  When Goal Seeking on Width with differential structures a dialog now appears to maintain the Constant Pitch.  This will then adjust the S1 parameter automatically as W1 / W2 changes to maintain the trace separation.
On the Frequency Dependent tab the structure parameters are now displayed in a tool tip that appears when the mouse is over the Information icon (i)
New Save Current Settings as Defaults.  Retain configuration parameters, units and interface style etc between sessions.
New Graph.  S11 / S21 on Smith Chart
New Graph. S-Parameter S11 - Magnitude (dB)
New Graph. S-Parameter S11 - Phase
New Graph. S-Parameter S21 - Magnitude (dB)
New Graph. S-Parameter S21 - Phase
Additional validation checks for S-Parameter Steps and Rise Time entry fields
Improved data export capabilities - formatting of RLGC / S-Parameters
New Import Si8000 Database option
Fix. Print Setup problem that occurs when File - Open has previously been used
Fix. Korean printing problem as reported by Calvin, Mr Bae
Fix. Minor user interface issues such as parameter hot spot positions (red box on structure graphics) and trends
Fix. “Divide by 0” error under the Frequency Dependent calculation when T1 = 0
Si9000e Changes v6.10
New Frequency Distribution option
New File - Export TouchStone Format option
Frequency Steps limit increased from 200 to 2000
Display new Magnitude and Phase tabs
Increase graphing data point limits
Insertion Loss renamed to Attenuation
Improved multilingual support
Online help now supports multilingual
New Trace Conductivity validation check
Corrections of broadside coupled 3S structure results
Improve users ability to stop differential calculations
Improve indication of progress during differential calculations
Provide more support information on About screen
Many other minor enhancements
Si9000e Changes v6.00
First release of Si9000e
发表于 2013-1-3 18:32:24 | 显示全部楼层
很好!但不太懂
GMT+8, 2024-5-4 11:48 , Processed in 0.267107 second(s), 19 queries .
