我在导网表时出现下面错误,不知什么原因,请大家帮忙啊 器件库和.brd文件是放在同一路径下的 Cadence Design Systems, Inc. netrev 15.5 Wed Dec 19 13:38:47 2007 (C) Copyright 2002 Cadence Design Systems, Inc. ------ Directives ------ RIPUP_ETCH TRUE; RIPUP_SYMBOLS ALWAYS; MISSING SYMBOL AS ERROR FALSE; SCHEMATIC_DIRECTORY '.'; BOARD_DIRECTORY ''; OLD_BOARD_NAME 'D:/新建文件夹/1.brd'; NEW_BOARD_NAME 'D:/新建文件夹/1.brd'; CmdLine: netrev -$ -5 -i . -x -y 1 -z D:/新建文件夹/gps-v2-1110/#Taaaaaa12884.tmp ------ Preparing to read pst files ------ #1 ERROR(24) File not found Packager files not found
#2 ERROR(102) Run stopped because errors were detected netrev run on Dec 19 13:38:47 2007 COMPILE 'logic' CHECK_PIN_NAMES OFF CROSS_REFERENCE OFF FEEDBACK OFF INCREMENTAL OFF INTERFACE_TYPE PHYSICAL MAX_ERRORS 500 MERGE_MINIMUM 5 NET_NAME_CHARS '#%&()*+-./:=>?@[]^_`|' NET_NAME_LENGTH 24 OVERSIGHTS ON REPLACE_CHECK OFF SINGLE_NODE_NETS ON SPLIT_MINIMUM 0 SUPPRESS 20 WARNINGS ON 2 errors detected No oversight detected No warning detected cpu time 0:00:06 elapsed time 0:00:00 |
