TO riverpeak 我的SET Library上设置是指向CDBFILE啊,但连接的时候有就连不上,还有环境变量怎么设置的啊 例如: 1.SD转BD选RULE时 选层时候,里边层RULE可看见,但都是灰色的不让选,MASSAGE显示:You can search Rules using Conductor Layer size.这是CDBFILE里的RUL文件不能选,但我COPY到我的电脑后把SET Library指向我的电脑里的CDBFILE 后可用。 2.但当我在画PCB时候,要COPY component frome CDB时候,再次不能连接, PART[R:...prt] connot connect to CR-5000 data server.The server version is old.update it to the lastest one. Package[R:...pkg] connot connect to CR-5000 data server.The server version is old.update it to the lastest one. Footprint[R:...ftp] connot connect to CR-5000 data server.The server version is old.update it to the lastest one. connot connect to CR-5000 data server.The server version is old.update it to the lastest one. Technology[R:...tch] connot connect to CR-5000 data server.The server version is old.update it to the lastest one. 问题如上 connot connect to CR-5000 data server.The server version is old.update it to the lastest one. 问题如上
[此贴子已经被作者于2008-1-22 13:36:14编辑过] |
