- 5612
楼主 |
发表于 2009-5-20 22:11:00
显示全部楼层
Ansoft发布HFSS 11.2,首次提供与Ansys V12的接口进行机械分析和热分析:
Version 11.2 Enhancements ============================================= HFSS is now able to export surface and volume losses in .xml file format for linking to an ANSYS Mechanical v12 thermal analysis.
DXF files can now be imported with .tech layer mapping files.
同时更新的还有Designer 4.1,Nexxim 4.1:
MAJOR ENHANCEMENTS Designer V4.1 --------------------------------
- General: o New S Parameter Analyzer tool - reorder matrix - renormalize matrix - adjust termination impedance - de-embed ports (if gamma is defined) - check passivity - look at statistics of data - color coded data tables and XY plots - color coded matrix display in multiple formats - compare two S matrices o New I/O Wizard to setup channels and IBIS buffers - rapid setup of IBIS drivers for large pin counts - ability to group individual items into sub-circuits - support parameterization of all component parameters (sources, power) - produces a fully functional final schematic o New option to only look at presolved data while tuning o New event callbacks that run before, during or after simulation o Bypass option for solver-on-demand models o Improved tuning speed by prevent engine reloading o Speed improvements in parameteric model data reading and writing o User can define different locations for syslib and userlib o Nexxim - DSO support for parametric sweeps - Dynamic links to Ansoft products: o Push excitations for QuickEye MAJOR ENHANCEMENTS Nexxim V4.1 -------------------------------- - General: o Support for remote analysis o User control of "errpreset" and "relref" in transient analysis o Support for slotline and suspended stripline substrates - Eye analysis: o Support for crosstalk analysis - bit pattern setup per source - UI, delay, per source. - control over num UI per step response o Receiver jitter analysis - post processing bathtub curves with PDF's o Receiver noise analysis o Peak distortion analysis (worst case bit patterns) o Support for 8b10b encoding - New components: o Coplanar Waveguide - Air Bridge - Air Bridge, Cross Over - Bend, Ground Plane Distance - Tapered line, Exponential - Tapered Line, Linear o Grounded Coplanar Waveguide - Air Bridge - Air Bridge, Cross Over - Bend, Ground Plane Distance - Tapered Line, Exponential - Tapered Line, Linear o Microstrip - Air Bridge - Optimally Mitered Bend - Arbitrary Mitered Bend - Bond Pad - Differential Lines, Field Solver (1, 2, 3, 4, and 5 pairs) - Transmission Line, Field Solver o Stripline - Optimally Mitered Bend - Differential Lines, Field Solver (1, 2, 3, 4, and 5 pairs) - Transmission Line, Field Solver o Suspended Stripline - Transmission Line, Physical Length - Transmission Line, Electrical Length o Slotline - Multicoupled Lines (2, 3, and 4) o Filters - Bessel-Thompson Bandpass - Bessel-Thompson Bandreject - Bessel-Thompson Highpass - Bessel-Thompson Lowpass - Elliptic Bandpass - Elliptic Bandreject - Elliptic Highpass - Elliptic Lowpass - Pole-Zero Bandpass - Pole-Zero Bandreject - Pole-Zero Highpass - Pole-Zero Lowpass - Polynomial Bandpass - Polynomial Bandreject - Polynomial Highpass - Polynomial Lowpass - S-Domain Transfer Function, Pole-Zero - S-Domain Transfer Function, Polynomial o Ideal Microwave - Antenna, Dipole - Antenna, Monopole - Microwave Link o Lumped General - Air Bridge, Rectangular Cross Section - Admittance Inverter - Impedance Inverter
Siwave 4.0即将发布:
SIwave v4.0 Enhancements:
Updated user interface - Improved layer stackup: ability to view vias on a layer by layer basis - Dynamic Zoom capability - Net Color mode - Editable Properties window - Find component based on Part Name or Reference Designator - Updated Reporter
Import/Export - BoardStation XE/RE import capability - Expedition v2007.x import capability - Layer stackup import and export - Apache CPM import - Component mapping file import (defines a partname as a specific type of component) Project setup - Package on PCB utility built into SIwave GUI - Ability to modify trace cross sections (trapezoidal or hexagonal) - Updated validation check - Improved scripting capabilities - Sketched and Low bondwire models are available - User can define an IC Die Network
Meshing - New mesh generation approach (geomproc instead of bsm_mesh). New tolerance meshing - Improved adaptive mesh refinment for DC solver using energy error indicators - Adaptive near field observation mesh
Solver - Multilayer MoM2D solver (improved trace models) - Multithreaded trace extraction - Trace bend modeling - Coplane and split plane coupling and the ability to view coupled segments after the simulation completes - New via model for improved accuracy - 64-bit eigen solver - DC IR drop solver improvements Resistance probe Port solve and Spice Net List solve using the DC solver Be able to view convergence analysis like in HFSS and Q3D Extractor - Far field and near field calculation updates - SIwizard for Designer/Nexxim link - Ability to run multiple solutions and access the results - New thin metal plane handling (solver will treat them as traces).
随着siwave 4.0的发布,maxwell控制面板将彻底消失。
