Export DXF MSITStore:\cr5000\help\eng\dxfoutgui.chm::htmlhelp/image/function.gif" width="20" border="0"/> Function Export DXF converts the specified CR-5000 database (PCB/PNL) into DXF file figure data. This allows you to transfer figure data from the CR-5000 system to another CAD system. This software converts the layers in a PCB into DXF layers. You can separate conductive layers into positive and negative layers when outputting them. MSITStore:\cr5000\help\eng\dxfoutgui.chm::htmlhelp/image/dialogs.gif" width="20" border="0"/> About the dialog box The configuration of the [Export DXF] dialog box is shown below. MSITStore:\cr5000\help\eng\dxfoutgui.chm::htmlhelp/image/dxfoutgui_e_shg.gif" width="600" usemap="#AreaMap0" border="0"/> MSITStore:\cr5000\help\eng\dxfoutgui.chm::htmlhelp/image/note.gif" width="20" border="0"/> Tips 1 For details of the functions and processes of Export DXF, refer to the "Batch Program Help". 2 The parameter file is also applicable to "dxfout," a batch-processing version of Export DXF. MSITStore:\cr5000\help\eng\dxfoutgui.chm::htmlhelp/image/caution.gif" width="20" border="0"/> Restrictions 1 License This tool does not check the license when it starts up. When used to output a figure, this tool requires a license for "dxfout," a batch-processing version of Export DXF. 2 If you load and overwrite an existing parameter using this tool, the comments will be lost even if you do not make any change to the parameter. 3 This tool does not support CLUI. 4 The information on the selection status and the values in the fields in the grayed-out buttons cannot be stored in the parameter file. The selection status and the values in the fields in the grayed-out buttons may change when the saved parameter file is opened. 5 This tool specifies RulesByArea as a nonconductive layer rather than a system layer. Also refer to the Restrictions on Export DXF in the Board Designer online help "Batch Program Help". |
