查看: 1275|回复: 1
[求助]出NC ROUTE 警告,什么意思?
发表于 2008-10-15 14:04:00 | 显示全部楼层 |阅读模式
(                    NC ROUTE LOG FILE                       )
(        Drawing    : RVEP3C5_5mil.brd                       )
(        Date/Time  : Wed Oct 15 13:27:47 2008               )
 rocessing NC Parameters file ...
 NC PARAMETERS
 FORMAT     3.5
 MACHINE-OFFSET  x:0.000000 y:0.000000
 FEEDRATE  1
 COORDINATES  ABSOLUTE
 OUTPUT-UNITS  ENGLISH
 TOOL-ORDER  INCREASING
 REPEAT-CODES  YES
 SUPPRESS-LEAD-ZEROES NO
 SUPPRESS-TRAIL-ZEROES NO
 SUPPRESS-EQUAL  NO
 TOOL-SELECT  NO
 HEADER   none
 LEADER   12
 CODE   ASCII
 SEPARATE  NO
 OPTIMIZE_DRILLING NO
 ENHANCED_EXCELLON NO
 SCALE   1.000000
 rocessing route path data ...
 WARNING: No route path data was found for processing.
 rocessing slot hole data ...
 WARNING: Can't find NC Route bit file (ncroutebits.txt)!
          Using T01 to route ALL route cuts.
 WARNING: No toolcode of a size the same as or smaller than 31 found for an OVAL slot!
          Defaulting to T01 as toolname.
 OVAL      slots routed: 3
 RECTANGLE slots routed: 0
 NC Route file RVEP3C5_5mil.rou created WITH WARNINGS ... Program completed.
请教,什么意思,加急啊。
 楼主| 发表于 2008-10-15 14:30:00 | 显示全部楼层
 rocessing tool file (ncroutebits.txt) ...
 NOTE: All units are assumed to be inches.
 0.025 T01
 0.030 T02
 0.050 T03
 0.075 T04
 No errors found.
 NC Route file RVEP3C5_5mil.rou created ... Program completed.
ncroutebits.txt,文件通过了。
还有个NC_ROUTE path,怎么画?
GMT+8, 2024-4-29 21:10 , Processed in 0.128058 second(s), 19 queries .
