(------------------------------------------------------------) ( ) ( NC ROUTE LOG FILE ) ( ) ( Drawing : RVEP3C5_5mil.brd ) ( Date/Time : Wed Oct 15 13:27:47 2008 ) ( ) (------------------------------------------------------------)  rocessing NC Parameters file ... NC PARAMETERS ------------- FORMAT 3.5 MACHINE-OFFSET x:0.000000 y:0.000000 FEEDRATE 1 COORDINATES ABSOLUTE OUTPUT-UNITS ENGLISH TOOL-ORDER INCREASING REPEAT-CODES YES SUPPRESS-LEAD-ZEROES NO SUPPRESS-TRAIL-ZEROES NO SUPPRESS-EQUAL NO TOOL-SELECT NO HEADER none LEADER 12 CODE ASCII SEPARATE NO OPTIMIZE_DRILLING NO ENHANCED_EXCELLON NO SCALE 1.000000 -------------------------------------------------------------  rocessing route path data ... WARNING: No route path data was found for processing. -------------------------------------------------------------  rocessing slot hole data ... WARNING: Can't find NC Route bit file (ncroutebits.txt)! Using T01 to route ALL route cuts. WARNING: No toolcode of a size the same as or smaller than 31 found for an OVAL slot! Defaulting to T01 as toolname. WARNING: No toolcode of a size the same as or smaller than 31 found for an OVAL slot! Defaulting to T01 as toolname. WARNING: No toolcode of a size the same as or smaller than 31 found for an OVAL slot! Defaulting to T01 as toolname. OVAL slots routed: 3 RECTANGLE slots routed: 0 ------------------------------------------------------------- NC Route file RVEP3C5_5mil.rou created WITH WARNINGS ... Program completed. 请教,什么意思,加急啊。 |
