查看: 1203|回复: 7
关于封装库
发表于 2003-4-7 13:41:00 | 显示全部楼层 |阅读模式
发表于 2003-4-7 17:33:00 | 显示全部楼层
要先转到ALLEGRO里面才能出到库里
 楼主| 发表于 2003-4-8 10:17:00 | 显示全部楼层
谢谢!我想知道,这些元件可以在转网络表时自动调进来吗?
发表于 2003-4-8 10:31:00 | 显示全部楼层
你说的是不是那些dra文件?
 楼主| 发表于 2003-4-8 12:45:00 | 显示全部楼层
不是,我说的是那些*.PSM文件
发表于 2003-4-8 12:55:00 | 显示全部楼层
可以啊,只要你跟你的BRD放在一个目录下,或者是指定的默认目录就可以了
 楼主| 发表于 2003-4-8 14:44:00 | 显示全部楼层
但是我用它转进BRD文件里时并没错,却看不到元件呢?
我用的是ALLEGRO 14.2 --ORCAD 9.2.3转入网络表时错误提示如下:
Tue Apr 08 09:56:41 2003    Page     1
Allegro NETLIST IN Log File
Netlist File Name: 'D:\a3\netlist.log'      Layout File Name: 'D:\USR\04363a.b~
rd\unnamed.brd'
{ Using PSTWRITER 14.2 P007Apr-08-2003 at 09:56:27 }
WARNING: Non-comment line preceding first keyword will be ignored.
#1 Warning [ALG0016] Part Name " C0603" is renamed to "C0603".
End of NETLIST IN Syntax/Logic Check
Total Netlist Warnings =  2.
Total Netlist Errors   =  0.
Total Combined Netlist and Device File Warnings =  2.
Total Combined Netlist and Device File Errors   =  0.
End of Allegro NETLIST IN Log
Starting gate assignment.     Tue Apr 08 09:56:41 2003
Assigning gates of drawing D:\USR\04363a.brd\unnamed.brd
Gates of differing rooms will not be assigned to the same component.
Gate assignment will use empty slots in existing components.
STEP I
STEP II
Finished with gate assignment.     Tue Apr 08 09:56:41 2003
发表于 2003-4-8 16:14:00 | 显示全部楼层
you can't see the components in the interface derectly, after you run the place command  ,you still can see them.
GMT+8, 2024-5-30 10:37 , Processed in 0.130219 second(s), 20 queries .
