转gerber时 出现下边提示,就是转不出来!怎么办?请高手指教! Can't open parameter file ... using default values: DEVICE-TYPE GERBER6X00 G-CODES NO STATIONS-PER-WHEEL 24 FILM-SIZE 24000 16000 COORDINATES ABSOLUTE OUTPUT-UNITS INCHES FORMAT 5.3 ABORT-ON-ERROR abort film & continue SUPPRESS-LEAD-ZEROES YES SUPPRESS-TRAIL-ZEROES NO OPTIMIZE YES SUPPRESS-EQUAL YES SCALE 1.0 WARNING: database resolution exceeds the resolution of the output coordinates (see FORMAT in parameter file). Some roundoff of coordinates may occur unless the number of decimal places in the output file is increased. ARTWORK Error reading apertures.
