- 4807
楼主 |
发表于 2003-4-22 10:44:00
显示全部楼层
MENTOR WG 2002 - Nodelocked(ethernet) license file installation guide
** If you have already installed a license for a previous product in the v2002 suite, this does not need to be repeated. **
1) Install the license utils from the licsrv/setup.exe, skip the configuration process.
2) Open/edit the file teamiso.src:
change this line =>
"FEATURE teamisokg mgcld 0000.00 01-jan-2010 0 0 HOSTID=000000000000"
change 000000000000 with your real 12 digits mac adress ( use lmtools.exe if needed )
DON'T EDIT NEITHER REMOVE ANY OTHER THING IN THIS SOURCE FILE
DON'T PUT MANUALY YOUR HOSTID ON ALL OTHER LINE BUT ONLY ON THE FIRST LINE!
DON'T RENAME SOUR
DON'T REMOVE FIRST LINE
2) Double click the "GenerateLicense.bat" batch file and create your "license.dat" file.
(a nag box will confirm the hostid)
3) copy the created licence.dat inside the C:\Mentor\WG2002\Licensing folder.
4) create/update both LM_LICENSE_FILE and MGLS_LICENSE_FILE environment variable/path,
as value put "C:\Mentor\WG2002\Licensing\license.dat"
5) Install your chosen Mentor product.
6) If needed, use the configure license utility for point the created license.dat (C:\Mentor\WG2002\Licensing\license.dat).
P.S: Incase of problem, read the flexlm manuals, u can also build server license with this licgen as well!
我按照上述安装,有问题。尤其是2) Double click the "GenerateLicense.bat" batch file and create your "license.dat" file.
(a nag box will confirm the hostid)并不能产生所谓的license.dat |
