Protel Design System Design Rule Check PCB File : Documents\PCB1.PCB Date : 28-Aug-2009 Time : 14:27:30 Processing Rule : Hole Size Constraint (Min=1mil) (Max=100mil) (On the board ) Rule Violations :0 Processing Rule : Width Constraint (Min=10mil) (Max=10mil) (Prefered=10mil) (On the board ) Rule Violations :0 Processing Rule : Clearance Constraint (Gap=10mil) (On the board ),(On the board ) Rule Violations :0 Processing Rule : Broken-Net Constraint ( (On the board ) ) Violation Net 01 is broken into 2 sub-nets. Routed To 85.71% Subnet : C2-1 C2-2 C1-1 C1-2 C3-1 C3-2 C4-2 Subnet : C4-1 Rule Violations :1 Processing Rule : Short-Circuit Constraint (Allowed=Not Allowed) (On the board ),(On the board ) Rule Violations :0 Violations Detected : 1 Time Elapsed : 00:00:00
