查看: 1875|回复: 5
500强 法资上海研发中心 招聘 Mentor Expedition PCB Layout工程师
发表于 2009-12-17 11:15:00 | 显示全部楼层 |阅读模式
公司介绍
阿海珐集团 (AREVA) 简介
AREVA集团凭借其遍布全球43个国家的生产设施以及100多个国家的销售网络,为客户提供高可靠性的技术用于无二氧化碳气体排放的电力生产及输配电。我们在核电领域处于世界领先地位,也是唯一的一家业务领域涉及核燃料循环各个环节的工业集团。
Role
The role is to design PCB layout for new and existing control and protection platforms. This individual shall be able to create PCB layout incorporating both analogue and digital circuitry and taking into account EMC, manufacturing and tests constraints. The candidate will have a good English level and will be able to work in collaborative way with international colleagues. The main activities are:
- Design multilayer PCB including placement of parts and routing of traces
- Manage parts library for schematic and PCB
- Setup design rules, class rules, high-speed rules
- Contribute to process optimization and productivity enhancements with international colleagues
Requirements
- Experience and knowledge in the following areas of PCB layout
- Digital/microprocessor
- Analogue
- Power supply
- Knowledge of Mentor tools is mandatory (PADS logic, layout, router)
- Experience using through-hole and SMT, fine pitch parts and ball grid array packages
- Ability to set up layer stack-up, select material, select surface finish and copper weight
- Ability to deliver optimized and cost effective PCB layouts
- Application of relevant EMC, RoHS and product safety legislation and an understanding of outside body approval requirements LVD, UL, CSA etc.
- Understanding of design for manufacture and design for test philosophies
- Familiar with latest board manufacturing process
- 3+ years experience in middle-high voltage PCB layout design
- Technical/Bachelor degree or equivalent work experience
- Good english communication skill, good team work spirit
有意者请将个人的中英文简历发送到:job.aspa@areva-td.com
 楼主| 发表于 2009-12-24 05:26:00 | 显示全部楼层
d[em04]
发表于 2009-12-25 10:43:00 | 显示全部楼层
帮顶一下。
发表于 2010-4-11 12:20:00 | 显示全部楼层
kan kan kan
发表于 2010-11-27 17:12:11 | 显示全部楼层
看看~~~~~
dennisyan 该用户已被删除
发表于 2011-1-3 02:12:54 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
GMT+8, 2025-5-15 23:21 , Processed in 0.136148 second(s), 20 queries .
