查看: 310|回复: 10
请帮我看看这种D码表怎么样读
发表于 2003-5-6 10:40:00 | 显示全部楼层 |阅读模式
请问怎么读这种D码表啊?
AP D11,CI,FL,0.2000
AP D12,CI,FL,0.3000
AP D13,CI,FL,0.4000
AP D14,CI,FL,0.5000
AP D15,CI,FL,0.6000
AP D16,CI,FL,0.7000
AP D17,CI,FL,0.8000
AP D18,CI,FL,0.9000
AP D19,CI,FL,1.0000
AP D20,CI,FL,1.2000
AP D21,CI,FL,1.3000
AP D24,CI,FL,2.0000
AP D25,CI,FL,2.2000
AP D27,CI,FL,2.5000
AP D29,CI,FL,3.0000
AP D36,CI,FL,0.3500
AP D38,CI,FL,0.2500
AP D43,CI,FL,0.7000
AP D44,CI,FL,0.8000
AP D45,CI,FL,0.9000
AP D46,CI,FL,1.0000
AP D47,CI,FL,1.2000
AP D48,CI,FL,1.4000
AP D49,CI,FL,1.5000
AP D50,CI,FL,1.6000
AP D51,CI,FL,2.0000
AP D52,CI,FL,2.2000
AP D53,CI,FL,2.4000
AP D54,CI,FL,2.8000
AP D55,CI,FL,3.0000
AP D56,CI,FL,3.2000
AP D60,CI,FL,8.0000
AP D68,SQ,FL,1.4000
AP D70,SQ,FL,1.6000
AP D72,SQ,FL,1.8000
AP D74,SQ,FL,2.0000
AP D77,SQ,FL,2.6000
AP D78,SQ,FL,2.8000
AP D83,CI,FL,2.5000
AP D89,SQ,FL,0.6000
AP D90,SQ,FL,0.7000
AP D91,SQ,FL,0.8000
AP D92,SQ,FL,0.9000
AP D93,SQ,FL,1.0000
AP D96,SQ,FL,1.3000
AP D99,SQ,FL,1.5000
AP D100,SQ,FL,1.6000
AP D102,SQ,FL,1.8000
AP D105,SQ,FL,2.2000
AP D107,SQ,FL,0.2500
AP D125,CI,FL,1.7000
AP D128,CI,FL,2.6000
AP D131,CI,FL,2.7000
AP D135,CI,FL,8.2000
AP D140,SQ,FL,0.4500
AP D142,SQ,FL,2.4000
AP D143,SQ,FL,2.6000
AP D156,CI,FL,1.8000
AP D157,SQ,FL,10.2000
AP D158,CI,FL,1.1000
AP D162,CI,FL,5.0000
AP D163,CI,FL,7.0000
AP D164,CI,FL,7.2000
AP D173,CI,FL,1.5000
AP D174,SQ,FL,10.0000
AP D175,CI,FL,0.1800
AP D176,CI,FL,1.3000
AP D196,SQ,FL,2.8000
发表于 2003-5-6 11:10:00 | 显示全部楼层
第二列是D-code编码,形状为第三列(CI为圆形round,SQ为方形Square),大小为第四列,在GC-CAM指定相关项,很容易就可以导入.
发表于 2003-5-6 12:03:00 | 显示全部楼层
AP: APERTURE  CI:CIRCLE  FL:FLASH  SQ:SQUARE
在写字板中使用查找/替换稍加编辑即可用任何软件读入!
D11    ROUNDED    0.2000
D12    ROUNDED    0.3000
D13    ROUNDED    0.4000
D14    ROUNDED    0.5000
D15    ROUNDED    0.6000
D16    ROUNDED    0.7000
D17    ROUNDED    0.8000
D18    ROUNDED    0.9000
D19    ROUNDED    1.0000
D20    ROUNDED    1.2000
D21    ROUNDED    1.3000
D24    ROUNDED    2.0000
D25    ROUNDED    2.2000
D27    ROUNDED    2.5000
D29    ROUNDED    3.0000
D36    ROUNDED    0.3500
D38    ROUNDED    0.2500
D43    ROUNDED    0.7000
D44    ROUNDED    0.8000
D45    ROUNDED    0.9000
D46    ROUNDED    1.0000
D47    ROUNDED    1.2000
D48    ROUNDED    1.4000
D49    ROUNDED    1.5000
D50    ROUNDED    1.6000
D51    ROUNDED    2.0000
D52    ROUNDED    2.2000
D53    ROUNDED    2.4000
D54    ROUNDED    2.8000
D55    ROUNDED    3.0000
D56    ROUNDED    3.2000
D60    ROUNDED    8.0000
D68    SQUARE    1.4000
D70    SQUARE    1.6000
D72    SQUARE    1.8000
D74    SQUARE    2.0000
D77    SQUARE    2.6000
D78    SQUARE    2.8000
D83    ROUNDED    2.5000
D89    SQUARE    0.6000
D90    SQUARE    0.7000
D91    SQUARE    0.8000
D92    SQUARE    0.9000
D93    SQUARE    1.0000
D96    SQUARE    1.3000
D99    SQUARE    1.5000
D100    SQUARE    1.6000
D102    SQUARE    1.8000
D105    SQUARE    2.2000
D107    SQUARE    0.2500
D125    ROUNDED    1.7000
D128    ROUNDED    2.6000
D131    ROUNDED    2.7000
D135    ROUNDED    8.2000
D140    SQUARE    0.4500
D142    SQUARE    2.4000
D143    SQUARE    2.6000
D156    ROUNDED    1.8000
D157    SQUARE    10.2000
D158    ROUNDED    1.1000
D162    ROUNDED    5.0000
D163    ROUNDED    7.0000
D164    ROUNDED    7.2000
D173    ROUNDED    1.5000
D174    SQUARE    10.0000
D175    ROUNDED    0.1800
D176    ROUNDED    1.3000
D196    SQUARE    2.8000
发表于 2003-5-6 15:00:00 | 显示全部楼层
用UCAM可读入。
 楼主| 发表于 2003-5-6 22:40:00 | 显示全部楼层
呵呵,多谢楼上各位啦!
二楼的说用GCCAM指定一些相关项,可以说清楚一些嘛??
三楼的嘛,这样要再编辑,我觉得挺麻烦的,以前我也编辑过,就是人懒了一点,不怎么想这样做了,呵呵!
我用V2001的CONVAPT这个命令将它转换了一下就可以读了,不过S码全部变成了R码,再将它改回来就可以了!
发表于 2003-5-6 23:50:00 | 显示全部楼层
不改也可以啊!S码本来就是R码的一种先特殊形式。你们认为呢?
发表于 2003-5-7 08:02:00 | 显示全部楼层
YCPCB:我以前也碰到过此情况,后来用GENESIS2000软件学习一下D-CODE之后就可读入了.
 楼主| 发表于 2003-5-7 09:59:00 | 显示全部楼层
你现在应该学得不错了吧,有时间教教我啊!!
发表于 2003-5-7 15:26:00 | 显示全部楼层
关键是能否安装上使用此软件
发表于 2003-5-7 15:44:00 | 显示全部楼层
我这里还有一个怪文件,看样子象小日本鬼子的,给大家试一下。
GMT+8, 2025-5-15 20:19 , Processed in 0.131137 second(s), 20 queries .
