查看: 1770|回复: 4
关于REUSE的问题
发表于 2010-1-13 16:31:00 | 显示全部楼层 |阅读模式
碰到REUSE的问题,不能进行下去,请用过的朋友指点下,谢谢!
=============Checking reuse/design compatibility=============
WARNING: Dielectric Constant mismatch (Layers 7-8)
   Dielectric Constant for Layers 7-8 in Design: 0.000000
   Dielectric Constant for Layers 7-8 in Reuse:  3.300000 (ignored)
WARNING: Dielectric Constant mismatch (Layers 8-9)
   Dielectric Constant for Layers 8-9 in Design: 0.000000
   Dielectric Constant for Layers 8-9 in Reuse:  3.300000 (ignored)
WARNING: Dielectric Constant mismatch (Layers 9-10)
   Dielectric Constant for Layers 9-10 in Design: 0.000000
   Dielectric Constant for Layers 9-10 in Reuse:  3.300000 (ignored)
WARNING: Dielectric Constant mismatch (Layers 10-11)
   Dielectric Constant for Layers 10-11 in Design: 0.000000
   Dielectric Constant for Layers 10-11 in Reuse:  3.300000 (ignored)
WARNING: Dielectric Constant mismatch (Layers 11-12)
   Dielectric Constant for Layers 11-12 in Design: 0.000000
   Dielectric Constant for Layers 11-12 in Reuse:  3.300000 (ignored)
WARNING: Dielectric Constant mismatch (Layers 12-13)
   Dielectric Constant for Layers 12-13 in Design: 0.000000
   Dielectric Constant for Layers 12-13 in Reuse:  3.300000 (ignored)
WARNING: Dielectric Constant mismatch (Layers 13-14)
   Dielectric Constant for Layers 13-14 in Design: 0.000000
   Dielectric Constant for Layers 13-14 in Reuse:  3.300000 (ignored)
WARNING: Dielectric Constant mismatch (Layers 14-15)
   Dielectric Constant for Layers 14-15 in Design: 0.000000
   Dielectric Constant for Layers 14-15 in Reuse:  3.300000 (ignored)
WARNING: Dielectric Constant mismatch (Layers 15-16)
   Dielectric Constant for Layers 15-16 in Design: 0.000000
   Dielectric Constant for Layers 15-16 in Reuse:  3.300000 (ignored)
WARNING: Dielectric Constant mismatch (Layers 16-17)
   Dielectric Constant for Layers 16-17 in Design: 0.000000
   Dielectric Constant for Layers 16-17 in Reuse:  3.300000 (ignored)
WARNING: Dielectric Constant mismatch (Layers 17-18)
   Dielectric Constant for Layers 17-18 in Design: 0.000000
   Dielectric Constant for Layers 17-18 in Reuse:  3.300000 (ignored)
WARNING: Dielectric Constant mismatch (Layers 18-19)
   Dielectric Constant for Layers 18-19 in Design: 0.000000
   Dielectric Constant for Layers 18-19 in Reuse:  3.300000 (ignored)
WARNING: Dielectric Constant mismatch (Layers 19-20)
   Dielectric Constant for Layers 19-20 in Design: 0.000000
   Dielectric Constant for Layers 19-20 in Reuse:  3.300000 (ignored)
WARNING: Dielectric Constant mismatch (Layers 20-21)
   Dielectric Constant for Layers 20-21 in Design: 0.000000
   Dielectric Constant for Layers 20-21 in Reuse:  3.300000 (ignored)
WARNING: Dielectric Constant mismatch (Layers 21-22)
   Dielectric Constant for Layers 21-22 in Design: 0.000000
   Dielectric Constant for Layers 21-22 in Reuse:  3.300000 (ignored)
WARNING: Dielectric Constant mismatch (Layers 22-23)
   Dielectric Constant for Layers 22-23 in Design: 0.000000
   Dielectric Constant for Layers 22-23 in Reuse:  3.300000 (ignored)
WARNING: Dielectric Constant mismatch (Layers 23-24)
   Dielectric Constant for Layers 23-24 in Design: 0.000000
   Dielectric Constant for Layers 23-24 in Reuse:  3.300000 (ignored)
WARNING: Dielectric Constant mismatch (Layers 24-25)
   Dielectric Constant for Layers 24-25 in Design: 0.000000
   Dielectric Constant for Layers 24-25 in Reuse:  3.300000 (ignored)
WARNING: Dielectric Constant mismatch (Layers 25-26)
   Dielectric Constant for Layers 25-26 in Design: 0.000000
   Dielectric Constant for Layers 25-26 in Reuse:  3.300000 (ignored)
WARNING: Dielectric Constant mismatch (Layers 26-27)
   Dielectric Constant for Layers 26-27 in Design: 0.000000
   Dielectric Constant for Layers 26-27 in Reuse:  3.300000 (ignored)
WARNING: Dielectric Constant mismatch (Layers 27-28)
   Dielectric Constant for Layers 27-28 in Design: 0.000000
   Dielectric Constant for Layers 27-28 in Reuse:  3.300000 (ignored)
WARNING: Dielectric Constant mismatch (Layers 28-29)
   Dielectric Constant for Layers 28-29 in Design: 0.000000
   Dielectric Constant for Layers 28-29 in Reuse:  3.300000 (ignored)
WARNING: Dielectric Constant mismatch (Layers 29-30)
   Dielectric Constant for Layers 29-30 in Design: 0.000000
   Dielectric Constant for Layers 29-30 in Reuse:  3.300000 (ignored)
WARNING: Dielectric Constant mismatch (Layers 30-31)
   Dielectric Constant for Layers 30-31 in Design: 0.000000
   Dielectric Constant for Layers 30-31 in Reuse:  3.300000 (ignored)
ERROR:   Gate pin Swap Type mismatch (Part Type LMSP33CA-465, gate #1)
   Pin #21840600 Swap Type for Part Type LMSP33CA-465 in design: 0
   Pin #105476736 Swap Type for Part Type LMSP33CA-465 in reuse:  -1
   Pin #105476760 Swap Type for Part Type LMSP33CA-465 in reuse:  -1
   Pin #105476784 Swap Type for Part Type LMSP33CA-465 in reuse:  -1
   Pin #105476808 Swap Type for Part Type LMSP33CA-465 in reuse:  -1
   Pin #105476832 Swap Type for Part Type LMSP33CA-465 in reuse:  -1
   Pin #105476856 Swap Type for Part Type LMSP33CA-465 in reuse:  -1
   Pin #105476880 Swap Type for Part Type LMSP33CA-465 in reuse:  -1
   Pin #105476904 Swap Type for Part Type LMSP33CA-465 in reuse:  -1
   Pin #105476928 Swap Type for Part Type LMSP33CA-465 in reuse:  -1
   Pin #105476952 Swap Type for Part Type LMSP33CA-465 in reuse:  -1
   Pin #105476976 Swap Type for Part Type LMSP33CA-465 in reuse:  -1
   Pin #105477000 Swap Type for Part Type LMSP33CA-465 in reuse:  -1
ERROR:   Logic family name mismatch (Part Type CAP-0603)
   Logic family name for Part Type CAP-0603 in design: CAP
   Logic family name for Part Type CAP-0603 in reuse:  UND
ERROR:   Gate pin number mismatch (Part Type CAP-0603, gate #1)
   Gate #1 pin number for Part Type CAP-0603 in design: 1
   Gate #1 pin number for Part Type CAP-0603 in reuse:  2
   Gate #1 pin number for Part Type CAP-0603 in design: 2
   Gate #1 pin number for Part Type CAP-0603 in reuse:  1
WARNING: Part Type CAP-0603 associated decal mismatch.
   Decal C0603 is absent in design.
   Reuse decal C0603 will be added to design.
WARNING: Attribute not assigned for object in design (Part Type CAP-0603)
   Attribute Material
   Attribute VAULE
发表于 2010-1-14 17:12:00 | 显示全部楼层
把这个Dielectric Constant DRC关掉
Gate pin Swap 设置不对
 楼主| 发表于 2010-1-19 12:02:00 | 显示全部楼层
大哥,不知这个Dielectric Constant DRC,具体在哪个位置,还烦劳讲解下!
发表于 2010-1-20 21:23:00 | 显示全部楼层
叠层设置和pcb库好像都有问题??
[em05]
发表于 2010-1-21 11:06:00 | 显示全部楼层
是的,层设置有问题,把层设置成最大
GMT+8, 2024-6-7 23:45 , Processed in 0.130941 second(s), 19 queries .
