- 836
发表于 2010-11-4 16:16:40
显示全部楼层
谢谢SUGAR,提供了个很新颖的思路,直接编辑合并P,N两个ASCII码文件,完成阴阳拼版,我试了了下合并P,N两个ASCII码文件两个文件,在CAM350导入查看,是正确的。只是不懂PERL,看来的学习PERL了。
请求SUGER,能否将你的rn.pl功能扩展下,合并两个ASCII码并另存命名。这样就造福人民了,人民感谢你,呵呵!
#!/usr/bin/perl -w
use Cwd;
my $dir = getcwd;
my $file_name="$dir/pcb/mfg/artwork_order";
& read_file($file_name);
sub read_file{my($file_name)=@_;
$i = -1;
@artwork_list = (artwork_1,artwork_2,artwork_3,artwork_4,artwork_5,artwork_6,artwork_7,artwork_8,artwork_9,artwork_10,artwork_11,artwork_12,artwork_13,artwork_14,artwork_15,
artwork_16,artwork_17,artwork_18,artwork_19,artwork_20,artwork_21,artwork_22,artwork_23,artwork_24,artwork_25,artwork_26,artwork_27,artwork_28,artwork_29,artwork_30);
open (MYFILE,"$file_name") || die ("Could not open this file!");
@array = <MYFILE>;
foreach $line (@array){foreach $al (@artwork_list)
{if (grep /\b$al\b/,$line)
{if (grep /signal/i,$line)
{rename $dir."/pcb/mfg/".$al, $dir."/pcb/mfg/"."LAY".$i.".GBR"}
elsif (grep /\bsolder_mask_1\b/i,$line){rename $dir."/pcb/mfg/".$al, $dir."/pcb/mfg/"."MASK1".".GBR"}
elsif (grep /\bsolder_mask_2\b/i,$line){rename $dir."/pcb/mfg/".$al, $dir."/pcb/mfg/"."MASK2".".GBR"}
elsif (grep /\bpaste_mask_1\b/i,$line){rename $dir."/pcb/mfg/".$al, $dir."/pcb/mfg/"."PASTE1".".GBR"}
elsif (grep /\bpaste_mask_2\b/i,$line){rename $dir."/pcb/mfg/".$al, $dir."/pcb/mfg/"."PASTE2".".GBR"}
elsif (grep /\bsilkscreen_1\b/i,$line){rename $dir."/pcb/mfg/".$al, $dir."/pcb/mfg/"."SILK1".".GBR"}
elsif (grep /\bsilkscreen_2\b/i,$line){rename $dir."/pcb/mfg/".$al, $dir."/pcb/mfg/"."SILK2".".GBR"}
elsif (grep /\bboard_outline\b/i,$line){rename $dir."/pcb/mfg/".$al, $dir."/pcb/mfg/"."OUTLINE".".GBR"}}}$i = $i+1;}
close(MYFILE);} |
