- 2280486
发表于 2012-12-18 11:24:19
显示全部楼层
JimY 发表于 2012-12-18 10:17
没有楼上2位那么复杂,这是AD的新功能,而不是什么Bug。你那彩虹形的飞线表示你这是跳线,所以DRC是检查不了 ...
http://wiki.altium.com/display/ADOH/Pad?focusedCommentId=16286147
Jumper Connections
Jumper connections define electrical connections between component pads that are not physically routed with primitives on the PCB. These are especially useful on single layer boards, where a wire is used to jump over tracks on the one physical layer, or even as complex as designing with a 'crossover' switch. The Design Rules Checker will not report jumper connections as unrouted nets.
Within a component, label pads that are to be connected by a jumper with the same Jumper ID value. Pads that share the same Jumper ID and electrical net tell the system that there is a legitimate, although physically unconnected, connection between them.
Jumper connections are shown as curved connection lines in the PCB Editor.
这么说,如果应用正确的话,就不存在提到的 DRC 问题了,多谢指点...
