查看: 788|回复: 0
MC68HC08JK8单片机特性简介
发表于 2013-10-30 13:57:57 | 显示全部楼层 |阅读模式
MC68HC08系列单片机采用CPU08内核,于1999年中期推出,以逐步实现MC68HC05各系列产品的升级换代。MC68HC08系列单片机包含十几个系列,一百多个型号。所有型号的单片机都集成了看门狗模块,定时器都是16位的,且具有输入捕捉、输出比较和脉宽调制功能。内含系统集成模块(System Integration Module,SIM),它是协调CPU与各模块时序关系的系统级控制器,主要实现时钟控制系统、复位控制系统和中断控制系统。
MC68HC08JK8 特性
xxHigh-Performance M68HC08 Architecture
Fully Upward-Compatible Object Code with M6805, M146805, and M68HC05 Families
Low-Power Design (Fully Static with Stop and Wait Modes)
Maximum internal bus frequency:
8-MHz at 5V operating voltage
4-MHz at 3V operating voltage
Oscillator options:
Crystal or resonator
RC oscillator
8,192 bytes of user FLASH memory with security feature
256 Bytes of On-Chip RAM
Two 16-bit, 2-channel inerface modules (TIM1 and TIM2) with selectable input capture, output compare, and PWM capability on TIM1 channels
10-channel, 8-bit analog-to-digital converter (ADC)
15 general-purpose input/output (I/O) ports:
1 keyboard interrupt with internal pull-up
4 LED drivers (sink)
2x25mA open-drain I/O with pull-up
Serial Communications Interface Module (SCI)
致芯科技承接各种芯片解密,更多解密资讯请咨询:010-57436216  15313166209  QQ:1002668449
GMT+8, 2025-7-12 14:55 , Processed in 0.171711 second(s), 24 queries .
