查看: 5117|回复: 15
Altium Designer 14.0.9.30380百度网盘分享
发表于 2013-11-5 12:52:34 | 显示全部楼层 |阅读模式
http://pan.baidu.com/share/link? ... 7&uk=2553358315Altium Designer 14.0.9.30380
Altium Designer 14.0.9.30380Tested Windows 7-x32, Windows 7-x64, Windows 8-x64, Windows 8.1-x64.——————————————————————————————————————————————————————————————————————————————————————————1. Install dotNetFx40_Full_x86_x64.exe2. Install TeighaX_Setup_3.9.0.msi3. Copy file _Program Files.exe in folder C:\\\\\\\\\\\\\\\\Program Files (for 32bit OS)   or folder C:\\\\\\\\\\\\\\\\Program Files (x86) (for 64bit OS)   and Run As Administrator4. Copy file _ProgramData.exe in folder %ProgramData%  (Windows 7/8)   or folder C:\\\\\\\\\\\\\\\\Documents and Settings\\\\\\\\\\\\\\\\All Users\\\\\\\\\\\\\\\\Application Data\\\\\\\\\\\\\\\\   (Windows XP)   and Run As Administrator   Warning!  After unpacking, check/change the access rights on folders Altium and Altium 2004. Check Modify Users group.  5. Copy file _Users_Public_Documents.exe in folder C:\\\\\\\\\\\\\\\\Users\\\\\\\\\\\\\\\\Public\\\\\\\\\\\\\\\\Documents (Windows 7/8)   or folder C:\\\\\\\\\\\\\\\\Documents and Settings\\\\\\\\\\\\\\\\All Users\\\\\\\\\\\\\\\\Documents\\\\\\\\\\\\\\\\  (Windows XP)   and Run As Administrator6. Add in reg: Altium_x32.reg - for 32bit OS Windows 7/8   or Altium_x64.reg - for 64bit OS Windows 7/8 Altium_x32XP.reg - for 32bit OS Windows XP  or Altium_x64XP.reg - for 64bit OS Windows XP7. Create a shortcut to start: C:\\\\\\\\\\\\\\\\Program Files\\\\\\\\\\\\\\\\Altium\\\\\\\\\\\\\\\\AD14\\\\\\\\\\\\\\\\             - for 32bit OS    or C:\\\\\\\\\\\\\\\\Program Files (x86)\\\\\\\\\\\\\\\\Altium\\\\\\\\\\\\\\\\AD14\\\\\\\\\\\\\\\\       - for 64bit OS Click right key mouse DXP.exe Create shortcut and install Desktop   or Send to -> Desktop (create shotcut).——————————————————————————————————————————————————————————————————————————————————————————Run Altium Designer. Use any 10 license
点评
有没有完整的安装文件?  发表于 2013-11-5 13:01
评分
参与人数 1金钱 +200 兑换点 +5 收起 理由
wanghanq + 200 + 5
查看全部评分
 楼主| 发表于 2013-11-5 13:00:44 | 显示全部楼层
智能系统设计自动化的全球领导者及3D PCB 设计解决方案(Altium Designer)和嵌入软件开发(TASKING)供应商Altium有限公司近日宣布推出其旗舰产品Altium Designer的最新版本Altium Designer 14。Altium Designer  14着重关注PCB核心设计技术,提供以客户为中心的全新平台,进一步夯实了Altium在原生3D PCB设计系统领域的领先地位。Altium Designer现已支持软性和软硬复合设计,将原理图捕获、3D PCB布线、分析及可编程设计等功能集成到单一的一体化解决方案中。 Altium Designer 14独特的原生3D视觉支持技术,可以在更小、更流动的空间内加速处理和通信过程,从而实现电子设计的创新。这一强化平台可实现更小的电子设计封装,从而在降低物料和制作成本的同时增加耐用性。  施耐德电气集团旗下Pelco公司的PCB设计工程师Narinder Kumar 表示:“我使用Altium软件产品已经近30年了。就我个人而言,我认为软硬复合设计是过去三年中最酷的新特性之一。Altium一直致力于在产品中提供突破性的技术和功能以满足客户需求。软硬复合设计这一功能我期待了很久,我非常喜欢这一功能。”  独特的3D高级电路板设计工具,面向主流设计人员  ● 软性和软硬复合PCB板的设计支持——新版{****}够实现软性和软硬复合板设计,包括先进的层堆栈管理技术  ● 支持嵌入式PCB元件——标准元件在制造过程中可安置于电路板内层,从而实现微型化设计  更为便捷的规则与约束设定实现全面高速的PCB设计  ● 简化高速设计规则,可实现差分对宽度设置的自动和制导调整,从而维持对阻抗的稳定性  ● 增强的过孔阵列技术(Via Stitching):强化了PCB编辑器的过孔阵列功能,能够将过孔阵列布局约束在用户定义区域  新向导提升了通用E-CAD和M-CAD格式的互用性  ● CadSoft Eagle导入工具——由于有些设计并未使用Altium Designer,出于兼容性的考虑,Altium推出CadSoft Eagle导入工具,从而方便客户使用其他格式的设计文件  ● Autodesk AutoCAD 导入/导出——最新技术支持设计文件在AutoCAD的  *.DWG 和*.DXF格式之间的相互转换。升级的导入/导出界面支持AutoCAD最新版本及更多对象类型  ● 直接使用IC管脚的IBIS模型,便于运用Altium Designer进行信号完整性分析 Altium Designer 14.0.9 (build 30380) | 1.7 Gb
http://www.0daydown.com/11/68649.html
点评
你给出的链接论坛里已有,是非正常安装版。  发表于 2013-11-5 13:04
 楼主| 发表于 2013-11-5 13:05:27 | 显示全部楼层
解压用   7ZIP  文件大小6.3G 导入附件中相关注册表文件后,打开DXP.EXE 加载ALF,然后就可以直接使用
发表于 2013-11-5 13:39:20 | 显示全部楼层
win8.1 系统中启动后闪退,用管理员身份运行就可以了。
发表于 2013-11-6 08:42:35 | 显示全部楼层
感恩版大等好久喔
发表于 2013-11-6 08:49:45 | 显示全部楼层
版大百度往盤需vip才能下可否在提供一個位址下感恩喔:\'(
发表于 2013-11-6 09:08:25 | 显示全部楼层
谢了哦,好东西。
发表于 2013-11-7 08:45:31 | 显示全部楼层
有完整版灭洋
发表于 2013-11-11 20:40:52 | 显示全部楼层
看帖回帖是一种美德
GMT+8, 2024-4-30 01:30 , Processed in 0.176688 second(s), 27 queries .
