查看: 3286|回复: 13
Altium Designer 14.3.11 Build 33708 再更新,速度伤不起!!!
发表于 2014-6-16 11:12:20 | 显示全部楼层 |阅读模式
更新的速度受不了了,
百度网盘:
种子未测试!!!
点评
再次重复: 初学者请找低版本学习(如 AD9.4.0.20159等),网速快且勇于测试者除外...  发表于 2014-6-16 18:23
评分
参与人数 2活跃度 +100 兑换点 +7 收起 理由
cai1116 + 100 + 2 更新速度跟不上节奏了。
wanghanq + 5
查看全部评分
发表于 2014-6-16 11:22:41 | 显示全部楼层
14版本起,BUG真是太多太严重了!更加伤不起!
发表于 2014-6-16 18:03:34 | 显示全部楼层
参考看看:
http://techdocs.altium.com/display/ADOH/Release+Notes+for+Altium+Designer+Version+14.3
Key feature highlights
Via Shielding ToolEnhanced Teardrop Control
Unused Pad Shape RemovalLength Tuning Enhancements
Interactive Routing ImprovementsControlling the Routing to an SMD Pad
Automatic Routing Neck-DownChamfered Routing
Enhanced Polygon Editing and ManagementEnhanced Editing of Polygonal Shapes
Enhanced PCB Filter PanelPCB Fixed Single Selection Order
Refactored Clearance Design RuleAutomatic Component Rotation on Polar Grid
Enhanced Jumper SupportExtended use of \'Flipped On Layer\' Property
Export a STEP Model of a Folded BoardImproved Diagonal Thermal Connections
PADS Importer EnhancementsxDx Designer Importer
IPC-7351B ComplianceActiveBOM Enhancements
Enhancements to VariantsSupplier Enhancements
Schematic Wire Drag ImprovementsDelete a Selected Wire Segment in Schematic
Schematic Font ImprovementsSpecify Text Margins for Text Frames and Notes
Verilog Include Paths and DefinesDialog-based New Project Creation
Smart PDF EnhancementsSystem & Performance Enhancements
File-less Editing in an Altium VaultCmpLib Editor Improvements
Vaults Panel Enhancements
Version 13.11Build:33708   Date: 13 June 2014
3241Exception no longer happens when copy/pasting component in cmplib editor.
3280Selecting an object in the PCB workspace now correctly selects that object in the PCB panel (Nets mode).
3296Alternate parts are no longer removed when opening an older design that includes variants.
3301Model and parameter inheritance in CmpLib files is now correctly handled when opening an older version CmpLib in AD14.3.
3273Handling of duplicate UIDs has been strengthened, to ensure that the compiled project correctly synchronizes with the PCB.
3304Editing a Part Choice List with insufficient rights no longer causes an exception.
Version 14.3.10Build:33625   Date: 4 June 2014
3219PCB Release process now continues correctly when non project documents are encountered.
3221Component variant parameters can now be changed back to their original values.
3222BOM documents can now update alternate variant components from database parameters.
3234Schematic connection highlighting no longer cause incorrect results after deleting wire segments.
3244The polygon pour order is now used correctly when rebuilding polygons. BC:4283
3245Varied components can now be restored to their original Fitted state.
3249PCB Design View layer visibility is now working correctly.
3256PCB string formatting issues when pasting from MS Excel documents has been fixed.
3278Polygon Pours now use the correct clearance rule values when rebuilding polygons.
Version 14.3.9Build:33548   Date: 29 May 2014
太多,省略...
发表于 2014-6-17 06:32:48 | 显示全部楼层
大哥, 你真忙, 謝謝你, 提供資訊.
看看也補.
发表于 2014-6-17 13:28:43 | 显示全部楼层
发表于 2014-6-17 15:38:33 | 显示全部楼层
菜单调成中文后,有很多地方是英文,很多功能和之前的版本有较大出如,有的菜单项可能会找不到!
点评
AD14.3.12已经出来,暂时未发现下载资源。  发表于 2014-7-5 08:41
AD14.3.12本地化语言就完善了。  发表于 2014-7-5 08:40
发表于 2014-7-2 01:33:25 | 显示全部楼层
太快啦 更新真快
发表于 2014-7-2 15:26:30 | 显示全部楼层
别下这个了,又出新版本了
发表于 2014-7-5 08:30:24 | 显示全部楼层
现是是14.3.12
点评
暂时未发现下载资源,耐心哦  详情 回复 发表于 2014-7-5 08:43
GMT+8, 2025-5-15 13:51 , Processed in 0.145976 second(s), 22 queries .
