查看: 1288|回复: 0
TY日记
发表于 2014-9-18 10:26:20 | 显示全部楼层 |阅读模式
公司简介:
     深圳市乾盛达科技有限公司为TY台湾半导体中国大陆唯一代理商。
TY台湾半导体有限公司于2002年成立于新北市,为专业之二、三极管封装厂。目前已通过ISO14001、TS16949及SONY GREEN PARTNER 等认证,产品为二、三极管封裝(SOT23、SOT523、SOT323、SOT23-5、SOT23-6、SOT143、SOT223、SOT89、SOD123、SOD323、SOD523 、SMA、SMB、SMC、0402、0603、0805、1206等等)。
免费服务热线:4008-318-123
QQ611720555
二极管、三极管、电容、电阻、电解、肖特基
2N5491    TO-220    2N5493    TO-220    2N6107    TO-220    2N6109    TO-220
2N6130    TO-220    2N6292    TO-220    2N6488    TO-220    2N6490    TO-220
2N6491    TO-220    2SA1010    TO-220    2SA1012    TO-220    2SA1069    TO-220
2SA1129    TO-220    2SA1328    TO-220    2SA1726    TO-220    2SA940    TO-220
2SA958    TO-220    2SA968    TO-220    2SB546    TO-220    2SB553    TO-220
2SB595    TO-220    2SB596    TO-220    2SB633    TO-220    2SB682    TO-220
2SB753    TO-220    2SB824    TO-220    2SB825    TO-220    2SB834    TO-220
2SB857    TO-220    2SB859    TO-220    2SB861    TO-220    2SC1061    TO-220
2SC2073    TO-220    2SC2233    TO-220    2SC2238    TO-220    2SC2275    TO-220
2SC2334    TO-220    2SC2336    TO-220    2SC2344    TO-220    2SC2373    TO-220
2SC2562    TO-220    2SC3345    TO-220    2SC4512    TO-220    2SD1061    TO-220
2SD1133    TO-220    2SD1138    TO-220    2SD2023    TO-220    2SD234    TO-220
2SD235    TO-220    2SD288    TO-220    2SD313    TO-220    2SD330    TO-220
2SD362    TO-220    2SD386    TO-220    2SD386A    TO-220    2SD401    TO-220
2SD402    TO-220    2SD475    TO-220    2SD526    TO-220    23D553    TO-220
2SD613    TO-220    2SD613    TO-220    2SD743    TO-220    2SD880    TO-220
BD201    TO-220    BD202    TO-220    BD239    TO-220    BD240    TO-220
BD241C    TO-220    BD242C    TO-220    BD243A    TO-220    BD243B    TO-220
BD243C    TO-220    BD244A    TO-220    BD244B    TO-220    BD244C    TO-220
BD277    TO-220    BD537    TO-220    BD538    TO-220    BD539    TO-220
BD539A    TO-220    BD539B    TO-220    BD539C    TO-220    BD544    TO-220
BD544A    TO-220    BD544B    TO-220    BD544C    TO-220    BD710    TO-220
BD711    TO-220    BD809    TO-220    BD810    TO-220    BD908    TO-220
BD910    TO-220    BD911    TO-220    BD912    TO-220    BD935    TO-220
BD941    TO-220    D44H10    TO-220    D44H11    TO-220    D44H8    TO-220
D44VH10    TO-220    D45C12    TO-220    D45H10    TO-220    D45H11    TO-220
D45H8    TO-220    D45VH10    TO-220    H1061    TO-220    MJE2955T TO-220
TIP29C    TO-220    TIP30C    TO-220    TIP31C    TO-220    TIP32C    TO-220
TIP41C    TO-220    TIP42C    TO-220    IRF630    TO-220    IRF634    TO-220
IRF640    TO-220    IRF730    TO-220    IRF740    TO-220    IRF830    TO-220
IRF840    TO-220    IRFZ44    TO-220    50N06    TO-220    60N06    TO-220
MBR10100CT    TO-220    MBR20100CT    TO-220    MBR30100CT    TO-220
TIC216M    TO-220    TIC246N    TO-220    2P4M    TO-220    BT134    TO-220
BT136    TO-220    BT137    TO-220    BT138    TO-220    BT139    TO-220
BT151    TO-220    BTA08    TO-220    BTA12    TO-220    BTA16    TO-220
BTB04    TO-220    BTB06    TO-220    BTB08    TO-220    2N2219    TO-220
BC140-10    TO-220    BC161    TO-220    2N2102    TO-220
2N2905A    TO-220
CDRH6D28-22UH贴片功率电感    TY
SDRH6D28-22UH贴片功率电感    TY
CDRH127-33UH额定电流3A大功率电感器    TY
CDRH8D43-33UH贴片功率电感器     TY
功率电感CDRH6D38-22UH    TY
功率电感CDRH6D38-100UH(直径7MM,高度3.8MM)     TY
CD75-33UH(直径7.8MM,高度5.0MM)大功率电感线圈     TY
CD75-10UH大功率电感器     TY
CD31-100UH贴片功率电感线圈(直径3.5MM,高度1.6MM)     TY
直插式***电感线圈SP0406-47UH     TY
直插式***电感器SP0406-100UH     TY    CDRH6D38-4.7UH贴片功率电感     TY
SDRH6D38-4.7UH贴片功率电感     TY    CDRH6D38-10UH贴片功率电感     TY
SDRH6D38-10UH贴片功率电感     TY    CDRH104R-68UH贴片功率电感器     TY
CDRH8D43-22UH贴片功率电感器     TY    大功率贴片电感器CDRH73-100UH     TY
贴片电感CDRH6D28-100UH(直径7MM,高度2.8MM)     TY
功率电感CDRH6D28-15UH(直径7MM,高度2.8MM)     TY
CDRH5D28-10UH(直径6MM,高度2.8MM)大功率电感器     TY
CDRH4D28-100UH(直径5MM,高度2.8MM)大功率电感线圈     TY
CD1054-33UH电感(直径10MM,高度5.4MM)功率电感线圈     TY
大功率贴片电感器CDRH74-47UH     TY
CD53-10UH大功率电感器     TY
CD1054-10UH电感(直径10MM,高度5.4MM)功率电感器     TY
CD54-220UH额定电流0.35A     TY
CD43-100UH贴片大功率电感器     TY
CD31-47UH贴片功率电感线圈(直径3.5MM,高度1.6MM)     TY
CDRH5D28-100UH(直径6MM,高度2.8MM)大功率电感器     TY
CD75-100UH大功率电感器     TY    CD75-47UH大功率电感器     TY
CD75-220UH电感贴片电感     TY    CD43-10UH贴片大功率电感线圈     TY
CDRH104R-22UH    TY    CDRH8D43-47UH贴片功率电感     TY
CDRH104R-10UH贴片功率电感     TY    直插式***电感器SP0810-1MH     TY
直插式***电感线圈SP0608-47UH     TY    CDRH127-22UH额定电流3.6大功率电感器     TY
大功率电感器CD1054-22UH     TY    CD54-22UH贴片电感器     TY
贴片功率电感器CD43-47UH     TY    CDRH3D16-100UH贴片功率电感     TY
CDRH6D28-2.2UH贴片功率电感     TY    CDRH4D18-68UH贴片功率电感     TY
CDRH5D18-22UH贴片功率电感     TY    贴片功率电感CDRH3D16-6.8UH     TY
CDRH6D28-220UH贴片功率电感     TY    CDRH4D18-22UH贴片功率电感     TY
贴片电感CDRH4D18-33UH     TY    功率电感器CDRH3D16-3.3UH     TY
直插功率电感SP0912-100UH    TY    直插功率电感SP0912-10UH     TY
CDRH6D38-2.2UH贴片功率电感     TY    CDRH5D18-6.8UH贴片功率电感     TY
CDRH6D28-100UH贴片功率电感     TY    贴片电感CDRH4D18-6.8UH     TY
CDRH104R-2.2UH贴片功率电感器     TY    CDRH104R-6.8UH贴片功率电感器     TY
CDRH104R-4.7UH贴片功率电感器     TY    直插功率电感SP0912-220UH     TY
CD75-22UH(7.8*7.2*5.0)     TY    一体成型大电流电感器0603-3R3M     TY
不带罩DO1608C-4R7M(0402-4.7UH)    TY    CDRH8D43-10UH贴片功率电感器     TY
直插功率电感SP0912-1000UH    TY    直插功率电感SP0912-22UH    TY
直插功率电感SP0912-33UH    TY    CDRH104R-33UH贴片功率电感器     TY
CDRH8D43-100UH贴片功率电感器     TY    CDRH8D43-2.2UH贴片功率电感器     TY
CDRH104R-220UH贴片功率电感器     TY    CDRH8D43-4.7UH贴片功率电感器     TY
原装台庆大电流电感SMPI 1205HW-6R8M     TY    原装台庆大电流电感SMPI 1004HW-1R5M     TY
原装台庆大电流电感SMPI 1004HW-5R6M     TY    原装台庆大电流电感SMPI 0603HW-1R5M     TY
原装TAI-TECH大电流电感SMPI 0603HW-3R3M     TY    原装台庆大电流电感SMPI 0603HW-4R7M     TY
原装台庆大电流电感SMPI 0603HW-2R2M     TY    大功率贴片电感器CDRH74-100UH     TY
CDRH74-10UH功率电感器     TY    CDRH7045-10UH功率电感器     TY
CD31-122M(CD3516-1.22MH贴片功率电感)     TY
CDRH5D28-22UH(直径6MM,高度2.8MM)大功率电感器     TY
CDRH5D18-4.7UH(直径6MM,高度1.8MM)大功率电感器     TY
CDRH5D28-2.2UH(直径6MM,高度2.8MM)大功率电感器     TY
CDRH5D18-2.2UH(直径6MM,高度1.8MM)大功率电感器     TY
CDRH4D28-4.7UH功率电感     TY
CDRH4D28-2.2UH贴片功率电感     TY
CDRH4D18-100UH(直径5MM,高度1.8MM)额定电流0.2A     TY
CDRH4D18-10UH(直径5MM,高度1.8MM)电感线圈电感器     TY
CDRH4D18-4.7UH(直径5MM,高度1.8MM)电感器     TY
CDRH4D18-2.2UH(直径5MM,高度1.8MM)大功率电感器     TY
CDRH3D16-22UH(直径4MM,高度1.6MM)大功率电感器     TY
大功率电感器CDRH3D16-10UH(直径4MM,高度1.6MM)     TY
CD53-47UH贴片大功率电感器     TY
CD42-4.7UH额定电流1.4A贴片功率电感器     TY
CD1040-10UH(直径10MM,高度4.0MM)大功率电感线圈     TY
CD75-470UH电感(直径7.8MM,高度5.0MM)贴片电感器     TY
CD75-4.7UH(直径7.8MM,高度5.0MM)额定电流4A电感器     TY
CD54-33UH贴片大功率电感器     TY
CD54-10UH贴片大功率电感器     TY
CD54-2.2UH大功率电感线圈     TY
CD32-47UH贴片功率电感器     TY
原装台庆大电流电感SMPI 1207HW-1R5M     TY
原装台庆大电流电感SMPI 1004HW-6R8M     TY
原装台庆大电流电感SMPI 1004HW-R30M     TY
原装台庆大电流电感SMPI 1004HW-100M     TY
大功率贴片电感器CDRH73-22UH     TY
大功率贴片电感器CDRH73-47UH     TY
大功率贴片电感器CDRH74-220UH     TY
CDRH5D28-470UH(直径6MM,高度2.8MM)大功率电感器     TY
CDRH5D28-33UH(直径6MM,高度2.8MM)大功率电感器     TY
CDRH5D18-10UH(直径6MM,高度1.8MM)大功率电感器     TY
CDRH4D28-33UH(直径5MM,高度2.8MM)大功率电感线圈     TY
CDRH4D28-68UH(直径5MM,高度2.8MM)大功率电感线圈     TY
CDRH4D18-47UH(直径5MM,高度1.8MM)电感器     TY
CDRH3D16-4.7UH功率电感器     TY
CD42-47UH大功率电感器     TY
CD1054-100UH(直径10MM,高度5.4MM)大功率贴片电感器     TY
CD54-68UH贴片大功率电感器     TY    CD54-4.7UH贴片大功率电感     TY
CD43-220UH额贴片大功率电感器     TY
CD43-33UH(直径**,高度3.2MM)贴片大功率电感器     TY
CD43-2.2UH(直径**,高度3.2MM)贴片大功率电感线圈     TY
CD32-220UH贴片功率电感器     TY
CD32-100UH贴片功率电感器(直径3.5MM,高度2.1MM)     TY
CD31-22UH贴片功率电感器(直径3.5MM,高度1.6MM)     TY
原装台庆大电流电感SMPI 1207HW-1R0M     TY
原装台庆大电流电感SMPI 1207HW-8R0M     TY
原装台庆大电流电感SMPI 1004HW-1R0M     TY
CDRH74-22UH SMD功率电感器     TY
CDRH74-4.7UH贴片功率电感器     TY
CDRH6D28-10UH(直径7MM,高度2.8MM)大功率电感器     TY
CDRH5D28-220UH(直径6MM,高度2.8MM)大功率电感器     TY
CDRH6D28-4.7UH贴片电感(直径7MM,高度2.8MM)     TY
CDRH4D28-220UH(直径5MM,高度2.8MM)大功率电感器     TY
CDRH4D28-47UH(直径5MM,高度2.8MM)大功率电感器     TY
CDRH6D28-22UH(直径7MM,高度2.8MM)大功率电感线圈     TY
CDRH6D28-47UH(直径7MM,高度2.8MM)大功率电感线圈     TY
CDRH5D28-47UH(直径6MM,高度2.8MM)大功率电感线圈     TY
CDRH5D28-4.7UH(直径6MM,高度2.8MM)大功率电感线圈     TY
CDRH5D18-47UH(直径6MM,高度1.8MM)大功率电感线圈     TY
CDRH4D28-470UH(直径5MM,高度2.8MM)大功率电感器     TY
CDRH4D28-10UH大功率电感器     TY
CDRH4D28-22UH(直径5MM,高度2.8MM)大功率电感器     TY
CDRH3D16-47UH(直径4MM,高度1.6MM)大功率电感线圈     TY
CDRH3D16-2.2UH(直径4MM,高度1.6MM)大功率电感线圈     TY
CD1054-220UH(直径10MM,高度5.4MM)大功率贴片电感器     TY
CD54-100UH额定电流0.52A贴片功率电感器     TY
CD54-6.8UH(直径5.8MM,高度**)贴片大功率电感器     TY
CD43-4.7UH贴片大功率电感器     TY
CD1054-330UH(直径10MM,高度5.4MM)大功率电感器     TY
CD1054-47UH(直径10MM,高度5.4MM)大功率贴片电感器     TY
CD31-2.2UH贴片功率电感器(直径3.5MM,高度1.6MM)     TY
CD32-4.7UH贴片功率电感线圈(直径3.5MM,高度2.1MM)     TY
电感CD73-47UH特价现货供应     TY
批量订做0520-2R2M一体成型大电流电感器     TY
批量订做0402-1R0M一体成型大电流电感线圈     TY
批量订做0402-1R5M一体成型大电流电感器     TY
批量订做0402-2R2M一体成型大电流电感器     TY
量订做0520-1R0M一体成型大电流电感线圈     TY
批量订做0520-6R8M大电流电感器     TY
批量订0520-3R3M一体成型大电流电感器     TY
特价订做0520-4R7M一体成型大电流电感线圈     TY
批量订做0520-5R6M一体成型大电流电感线圈     TY
台庆大电流电感SMPI 1354P3-4R7M     TY    (BUJEON)BDS-3412E-681MH-CO电感器     TY
进口超薄SDR5010-6R8M     TY    进口超薄SDR5010-100M     TY
进口超薄SDR5010-4R7M     TY    国产订做DV0630     TY
RH1608C-1UH大功率贴片电感器     TY    RH1608-6.8UH大功率贴片电感器     TY
RH1608-22UH大功率贴片电感线圈     TY    RH1608C-22UH大功率贴片电感器     TY
RH1608-470UH大功率贴片电感线圈     TY    CDRH104R-47UH电感器     TY
CDRH104R-100UH电感    TY    CDRH105R-10UH    TY
RH6028-4.7UH大功率贴片电感器     TY    CDRH103R-100UH    TY
RH6028-150UH大功率贴片电感器     TY    RH6028-330UH大功率贴片电感器     TY
CDRH74B-100UH     TY    直插式***电感SP1016-100UH电感线圈     TY
直插式***电感器SP0810-2.2MH     TY    直插式***电感器SP0912-150UH     TY
直插式***电感器SP0912-330UH     TY    直插式***电感线圈SP0912-33UH     TY
直插式***电感SP0810-470UH     TY    直插式***电感器SP1016-330UH     TY
直插式***电感SP0810-150UH     TY    直插式***电感线圈SP0912-47UH     TY
直插式***电感SP0810-330UH     TY    直插式***电感SP0810-22UH     TY
直插式***电感SP0810-220UH     TY    直插式***电感器SP0406-330UH     TY
直插式***电感线圈SP0608-22UH     TY    直插式***电感器SP0608-100UH     TY
直插式***电感器SP0608-10UH     TY    直插式***电感SP0608-15UH     TY
直插式***电感SP0810-100UH     TY    直插式***电感SP0810-47UH     TY
直插式***电感器SP0608-470UH     TY    直插式***电感SP0406-22UH     TY
直插式***电感SP0810-10UH     TY    直插式***电感器SP0608-1MH     TY
直插式***电感器SP0406-220UH     TY    直插式***电感线圈SP0608-150UH     TY
直插式***电感SP0406-15UH     TY    直插式***电感SP0406-10UH     TY
RH3316-3.3UH     TY    DRH124-100UH额定电流1.2A大功率电感器     TY
CDRH125-470UH额定电流0.58A大功率电感器     TY    CDRH124-33UH额定电流2.7A大功率电感器     TY
CDRH125-68UH额定电流1.5A大功率电感器     TY    CDRH125-330UH额定电流0.68A大功率电感器     TY
CDRH125-150UH额定电流1A大功率电感器     TY    CDRH125-100UH额定电流1.3A大功率电感器     TY
CDRH125-10UH额定电流4A大功率电感器     TY    CDRH125-22UH额定电流2.8A大功率电感器     TY
CDRH125-3.3UH额定电流8A大功率电感器     TY    CDRH125-4.7UH额定电流4.6A大功率电感器     TY
CDRH127-330UH额定电流0.95A大功率电感器     TY    CDRH125-2.2UH额定电流7.8A大功率电感器     TY
CDRH127-470UH额定电流0.79A大功率电感器     TY    CDRH127-150UH功率电感器     TY
CDRH125-220UH额定电流0.8A大功率电感器     TY    CDRH125-33UH额定电流2.1A大功率电感器     TY
CDRH125-15UH额定电流3.3A大功率电感器     TY    CDRH125-47UH大功率电感器     TY
CDRH127-68UH额定电流2.1A大功率电感器     TY    CDRH127-220UH额定电流1.16A大功率电感器     TY
CDRH127-3.3UH额定电流6.6A大功率电感器     TY    CDRH127-2.2UH额定电流8A大功率电感器     TY
CDRH127-10UH额定电流5.4A大功率电感器     TY    CDRH127-6.8UH额定电流6.6A大功率电感器     TY
CDRH127-47UH额定电流2.5A大功率电感器     TY    CDRH127-15UH功率电感器     TY
CDRH127-4R7额定电流6.8A大功率电感器     TY    MP3,MP4常用电感器CD32-10UH(不印字不编带)     TY
CD32-2.2UH大功率贴片电感器(直径3.5MM,高度2.1MM)     TY
CD31-3.3UH大功率贴片电感器(直径3.5MM,高度1.6MM)     TY
大功率电感器CD31-10UH(直径3.5MM,高度1.6MM)     TY    CD43-22UH额定电流0.76A电感     TY
CD32-22UH额定电流0.63A     TY    工作电流9安,饱和电流16安1205-10UH特大电流贴片电感器     TY
工作电流10安,饱和电流18安1205-8.2UH特大电流贴片电感器     TY
工作电流11安,饱和电流21安1205-6.8UH特大电流贴片电感器     TY
供应工作电流12安,饱和电流22安1205-5R6特大电流电感器     TY
供应工作电流12安,饱和电流27安1205-4R7特大电流电感器     TY
供应工作电流15安,饱和电流32安1205-3.3UH特大电流电感器     TY
供应工作电流17安,饱和电流32安1205-2.2UH特大电流电感器     TY
供应工作电流19安,饱和电流40安1205-1.8UH特大电流电感器     TY
供应工作电流23安,饱和电流48安1205-1R5特大电流电感器     TY
特价供应特电电流12X12X5-1R2,工作电流25A饱和电流48A     TY
特价供应特电电流12X12X5-1R0,工作电流29A饱和电流49A电感器     TY
供应一体成型特大电流1205-R68(工作电流34A,饱和电流54A)     TY
供应工作电流36安,饱和电流55安1205-R56特大电流电感线圈     TY
供应特大电流1205-R33(工作电流42A,饱和电流80A)电感器     TY
特价供应特电电流12X12X5-R22,工作电流51A     TY
特价供应特电电流12X12X5-R10,工作电流15A     TY
特价供应大电流电感器SD0603-10UH,工作电流3A     TY
特价供应特大电流电感器DS0603-8.2U,电流4A     TY
特价供应特大电流电感器SD0603-6.8UH     TY
特价供应特大电流电感线圈SD0603-4.7UH,工作电流4.8安     TY
特价供应SD0603-2.2UH,特大工作电流6.8安大功率电感器     TY
特价供应大电流电感0603-1R5,工作电流7.7安电感线圈     TY
价供应特大电流电感SD0603-1UH,工作电流9.5A     TY
特价供应SD0603-0.68UH特大工作电流12.6A电感     TY
供应特大电流SD1004-10UH(工作电流2.5A,饱和电流5.5A)电感器     TY
供应特大电流SD1004-1.5uh(工作电流12A,饱和电流19A)电感器     TY
供应特大电流SD1004-8.2UH(工作电流5A,饱和电流7A)电感线圈     TY
供应特大电流SD1004-6R8(工作电流7A,饱和电流10A)电感器     TY
供应特大电流SD1004-4.7UH(工作电流8A,饱和电流13A)电感器     TY
供应特大电流SD1004-3R3(工作电流10A,饱和电流14A)电感器     TY
供应特大电流SD1004-2.2uh(工作电流11A,饱和电流17A)电感线圈     TY
供应特大电流SD1004-1uh(工作电流19A,饱和电流25A)电感器     TY
供应特大电流SD1004-0.68uh(工作电流22A,饱和电流330A)电感     TY
物价供应线艺74B-10UH大功率电感器     TY
供应工作电流38安,饱和电流65安1205-R47大电流电感     TY
贴片功率电感器:2D11-10UH     TY
贴片功率电感:CD32-10UH(直径3.5MM,高度2.1MM)     TY
贴片电感:6028-100UH     TY
CD31-4.7UH功率贴片电感(直径3.5MM,高度1.6MM)     TY
CDRH2D14-10UH功率贴片电感器     TY    CD54-47UH功率贴片电感     TY
CDRH3316-3.3UH功率贴片电感器     TY    CDRH3316-2.2UH功率贴片电感器     TY
CDRH5022-330UH功率贴片电感     TY    CDRH127-100UH贴片电感器     TY
CDRH53LB-10UH功率贴片电感     TY    CDRH104R-15UH     TY
127    TY    47    127    TY    100    127    TY    33
127    TY    4.7    127    TY    220    127    TY    68
125    TY    47    125    TY    22    125    TY    100
125    TY    33    127    TY    10    127    TY    330
127    TY    22    RH73    TY    680    0603    TY    10
104R    TY    15    104R    TY    100    104R    TY    47
104R    TY    4.7    104R    TY    33    104R    TY    6.8
104R    TY    2.2    104R    TY    10    104R    TY    22
104R    TY    68    104R    TY    150    3D16    TY    10
2D14    TY    15    LPF4017-3R3N    TY    3.3    LPF5017T-100M    TY    10
GMT+8, 2024-5-3 06:29 , Processed in 0.128580 second(s), 20 queries .
