- 38
file:///C:\\Users\\Riven\\AppData\\Roaming\\Tencent\\Users\\761640809\\QQ\\WinTemp\\RichOle\\Y17HTIJPIR~R$7LNI``QZHE.png#324 ERROR(ORCAP-36022): Pin number missing from Pin \"1\" of Package 1K,1/10W,1%,SMD0603 , R57: SCHEMATIC1, P03. Power Switch (4.00, 1.40). All pins should be numbered.
#325 ERROR(ORCAP-36022): Pin number missing from Pin \"2\" of Package 1K,1/10W,1%,SMD0603 , R57: SCHEMATIC1, P03. Power Switch (4.00, 1.40). All pins should be numbered.
#326 ERROR(ORCAP-36022): Pin number missing from Pin \"1\" of Package 0.1uF,25V,20%,SMD0402 , CB1: SCHEMATIC1, P03. Power Switch (1.30, 2.00). All pins should be numbered.
#327 ERROR(ORCAP-36022): Pin number missing from Pin \"2\" of Package 0.1uF,25V,20%,SMD0402 , CB1: SCHEMATIC1, P03. Power Switch (1.30, 2.00). All pins should be numbered.
#328 ERROR(ORCAP-36022): Pin number missing from Pin \"1\" of Package 0.1uF,25V,20%,SMD0402 , C44: SCHEMATIC1, P02. DP to HDMI (13.20, 7.50). All pins should be numbered.
#329 ERROR(ORCAP-36022): Pin number missing from Pin
\"2\" of Package 0.1uF,25V,20%,SMD0402 , C44: SCHEMATIC1, P02. DP to HDMI (13.20, 7.50). All pins should be numbered.
#330 ERROR(ORCAP-36022): Pin number missing from Pin \"1\" of Package 1K,1/10W,1%,SMD0603 , R68: SCHEMATIC1, P04. System Power (12.20, 3.10). All pins should be numbered.
#331 ERROR(ORCAP-36022): Pin number missing from Pin \"2\" of Package 1K,1/10W,1%,SMD0603 , R68: SCHEMATIC1, P04. System Power (12.20, 3.10). All pins should be numbered.
#332 ERROR(ORCAP-36022): Pin number missing from Pin \"1\" of Package 1K,1/10W,1%,SMD0603 , R46: SCHEMATIC1, P02. DP to HDMI (7.80, 8.00). All pins should be numbered.
#333 ERROR(ORCAP-36022): Pin number missing from Pin \"2\" of Package 1K,1/10W,1%,SMD0603 , R46: SCHEMATIC1, P02. DP to HDMI (7.80, 8.00). All pins should be numbered.
#334 ERROR(ORCAP-36022): Pin number missing from Pin \"1\" of Package 1uF,16V,20%,SMD0603 , C55: SCHEMATIC1, P02. DP to HDMI (4.90, 8.30). All pins should be numbered.
#335 ERROR(ORCAP-36022): Pin number missing from Pin \"2\" of Packa
