楼主: luluyy
AltiumDesignerSetup_17_1_5 Build: 472
发表于 2017-3-1 17:07:46 | 显示全部楼层
ersion 17.0.11
Build: 656 Date: 28 February 2017
16348         Updated Release Manager, so in Folder mode, the user has the choice to release to a file or a folder.
16349         Added ability to use special symbols (allowed by OS) in Target Folder attributes (/). Inherit the target folder name from the recognized Configuration name. Allow renaming custom section names (better restructure data using custom release structure).
16351         Relieved restriction on the custom section target items in Release Manager, so they can point to other types except the binary files.
16384         Fixed regression bug that caused an access violation for Step 3D export (TKShHealing.dll).
16502         Fixed graphical glitch with the drop down control under Windows 7.
16503         Fixed import preferences dialog so it no longer shows an incorrect icon in the import settings dialog.
16528         Fixed regression bug that caused DXP to crash after trying to use a revision naming scheme with Revision ID format equal to \"ASME_Y14_35M\".
16615         Scripting - Fixed regression bug where Format function does not format strings.
16648         Fixed regression bug that caused AD to crash when navigating to an item in Vault Explorer that was released with a custom lifecycle.
16707         Fixed regression bug in Vault Explorer where random footprint preview shown for different parts when a component has a simulation model.
发表于 2017-3-1 16:57:31 | 显示全部楼层
又更新了,17.10装上还没怎么用呢,啥时后大神给分享一下
发表于 2017-3-1 16:31:14 | 显示全部楼层
l10g24 发表于 2017-3-1 14:38
我AD17.0.09-0..10都还没用过又出AD17.0.11了
果然又更新了,.10都没下
发表于 2017-3-1 14:38:53 | 显示全部楼层
点评
果然又更新了,.10都没下  详情 回复 发表于 2017-3-1 16:31
发表于 2017-3-1 14:35:13 | 显示全部楼层
安装的时候要账户密码
点评
有没有,发一个序列号  详情 回复 发表于 2017-5-12 19:15
回复 支持 1 反对 0
发表于 2017-3-1 07:17:16 | 显示全部楼层
17.0.11 上线了。
发表于 2017-2-24 12:22:19 | 显示全部楼层
谢谢!下载看看。
发表于 2017-2-13 08:50:44 | 显示全部楼层
不知道大神有没有方法,让我们试试新的PDN Analyzer这个extension呢?
发表于 2017-2-12 18:24:11 | 显示全部楼层
又出新版了,这速度
发表于 2017-2-11 16:44:43 | 显示全部楼层
感谢 luluyy
GMT+8, 2024-5-3 02:02 , Processed in 0.142992 second(s), 16 queries .
