43550 | The Edit > Replace Text menu command does not function correctly when wildcards are used in the Text To Find field. |
44111 | Implemented a "Schematic was done in newer version" warning to notify users that new functionalities were introduced between the version of Altium Designer that was used to create the schematic and the version used to open the schematic document. |
45068 | The last copied object was not always pasted on schematic when Copy/Paste commands were executed very fast. ( BC:15686) |
45810 | The Show Net Color Override command does not work correctly when using F5 or when invoking the command from the View menu. ( BC:16912) |
45967 | A background compilation error occurred after opening a specific project, and a crash occurred after performing some operations on its schematics. |
46017 | The value of the VersionControl_RevNumber special string was not displayed on the schematic in a particular case. |
46066 | The Find Text - Jump dialog can now be closed by using the Esc key. ( BC:7891) |
46166 | Added ability to show all Parameters in the Component mode of the Properties panel. ( BC:16344) |
46269 | Two digital numbers surrounded by parentheses were interpreted as a number rather than a string in the concatenation of parameters. ( BC:16816) |
44018 | Document could not be saved after reconnecting to a VPN. ( BC:15217) |
44822 | Software performance degradation during layer cycling when a routing via needs to push too many objects. |
45535 | When placing non-inverted graphics, some QR codes are placed incorrectly with an extra filled rectangle. ( BC:16478) |
45536 | Location of the ".VersionControl Rev Number" special string was changed on a PCB after saving the document. ( BC:16458) |
45589 | Moved layers resulted in incorrect page sequence in outputs. |
45751 | Work guides disappeared while slicing polygons. |
45783 | A custom grid was not displayed on a PCB until a new grid is added. |
45895 | Added the Room mode of the Properties panel. ( BC:9310) |
45971 | When a polygon cutout is indirectly built to a net tie footprint, using the 'Verify Shorting Copper' option of the DRC generates a net tie verification failure. |
46150 | Hatched polygon pours do not respect polygon pour cutout boundaries. ( BC:3579) |
46151 | Improvements for interactive routing with SMT rules include rules are now applied when using 'Any Angle', routing does not fail if all allowed exits are blocked, and routing is more stable after exiting an SMD. |
46180 | If a Line primitive is not on any of the assembly layers used in a component, the Variant 'Drawing Style' is not applied. |
46251 | When generating a Gerber report with a design view that is mirrored, the layer description and layer extension do not match. ( BC:12325) |
46263 | The layer order was not changed when using an Embedded Board Array. ( BC:11150) |
46265 | Blind vias were copied and pasted incorrectly onto a board, |
44762 | When a project is released, the .zip file that is created is not named correctly using the project parameters. ( BC:15515) |
45762 | Performance degradation occurred when opening a PCB if there is an issue with the Collaboration Service connection. |
45790 | When File > Open Project > Local Projects tab is clicked, the system freezes. |
45923 | An incorrect icon was used for the 'Comments' command in the right-click menu of the schematic and PCB editors and on the Schematic Standard toolbar. |
45943 | Performance degradation occurred when pressing the Ctrl+Tab shortcut if libraries on a network share are used. |
45969 | A pinned or docked state of a panel was not saved after software relaunch. ( BC:9777) |
45804 | The ability to sweep more than two parameters in the Parametric Sweep has been added. ( BC:16615) |
45940 | The X,Y scale settings for plots are now kept during the simulation process for opened and saved .sdf documents. |
46036 | Voltage on an independent voltage source is now supported as an output variable in DC and Transient Analysis. |
46042 | Power on functional voltage and current sources is now supported as an output variable in DC and Transient Analysis. |
46044 | Voltage on a capacitor is now supported as an output variable in DC and Transient Analysis. |
46046 | Voltage on the current switch is now supported as an output variable in DC and Transient Analysis. |
46047 | Charge on a capacitor is now supported as an output variable in DC and Transient Analysis. |
46049 | Current for an independent current source model is now supported as an output variable in DC and Transient Analysis. |
46051 | Conductance on a current switch is now supported as an output variable in DC and Transient Analysis. |
46056 | Voltage on a voltage switch is now supported as an output variable in DC and Transient Analysis. |
46059 | Conductance on a voltage switch is now supported as an output variable in DC and Transient Analysis. |
46062 | Added Waveforms and Functions drop-downs in the Add Output Expression dialog. |
