38985 | Some bitmaps were truncated in the generated PDF document. ( BC:13051) |
42470 | The Smart PDF output did not include embedded graphics. ( BC:17255) |
45086 | An error occurred when running the Smart PDF wizard for a free document. |
45924 | WMF and GIF graphics were not printed to PDF by Smart PDF and other tools. |
46099 | When the revision of the managed sheet is replaced, the Annotation file becomes invalid. ( BC:15715) |
46176 | The Edit > Refactor > Move Selected Subcircuit to Different Sheet command changes the Unique IDs of the parts. ( BC:16785) |
46690 | Custom locations of cross reference parameters are reset to defaults after saving and reloading the schematic document. ( BC:17084) |
46734 | The page scaling in the Print dialog was displayed incorrectly. ( BC:17058) |
46796 | Superscripts located in multi-channels displayed the previous designator rather than the logical designator. ( BC:17099) |
46853 | Wires disappeared when dragging before using the Edit > Refactor command. |
46906 | The Physical checkbox in the Component Designator dialog will maintain its enabled or disabled state until the software is closed. ( BC:12819) |
46977 | Changed the direction when adding additional ports and pins. |
47055 | Wire names were not displayed in the tooltip in free documents. |
44082 | Traces did not automatically change their width until a trace was placed in the flex region. |
45841 | Values of alternate part parameters were missing for a design variant that is not selected. ( BC:15365) |
46209 | Error appeared when exporting a Parasolid file when the 'Export All Copper' option was enabled. ( BC:15929) |
46556 | The rotation column did not respect the comma and period separator change in the Pick and Place Setup dialog. ( BC:15556) |
46842 | A crash occurred after loading a stackup, saving the Layer Stack Manager, then returning to the PCB document. |
46992 | No Net split planes were not detected in the Unrouted Net rule. ( BC:12252) |
47061 | Unnecessary controls were selected when using the Tab keyboard shortcut in some object properties panels ( BC:11281) |
47127 | Pads that were set to 'rectangular' and contained a hole size equal to its length were not displayed in the Drill Table. |
47129 | Discontinuity occurred in generated STEP files if a bending angle contained a negative value. |
47182 | Hatched polygon pour did not obey polygon cutouts near obstacles, which caused violations to occur. |
47192 | Polygon pour speed was improved for complex boards with a big number of pads or vias. |
47227 | The 'Obey Polygon Cutout' option has been added to the Polygon Pour properties. |
47261 | Routing with conflict resolution on 'Push Obstacles' caused the software to crash. |
