查看: 950|回复: 6
请教:powerpcb栅格设置问题
发表于 2003-12-3 00:04:46 | 显示全部楼层 |阅读模式
 楼主| 发表于 2003-12-3 00:07:06 | 显示全部楼层
好象是热键G不管用
GD却可以
是版本问题吗?
 楼主| 发表于 2003-12-3 00:15:11 | 显示全部楼层
他设置栅格的热键有那些?
1、G 设置全局栅格
2、GD 设置显示栅格
3、GV  ?
4、GR   设置设计栅格
我试了一下就热键“G”管用,别的好象都不行
为什么?请教!
发表于 2003-12-3 07:20:17 | 显示全部楼层
不可能不管用,刚试过,G、GD设置均正常
 楼主| 发表于 2003-12-3 20:37:03 | 显示全部楼层
为什么我的不行
发表于 2003-12-4 08:38:39 | 显示全部楼层
Grids G {} Grid global setting. The second parameter is optional. Sets the Design and Via grids simultaneously, for example, G 25, G 8.3 or G 16-2/3, G 25 25. GD {} Dot grid setting, for example, GD 8-1/3, GD 25 25, or GD 100. The second parameter is optional. GP Polar grid on/off. Use the polar grid for Radial Move, circular component arrays, and to create radial drawings. GP r a Move to a point specified by polar coordinates (radius and angle). GPR r Move to a point specified by the radius, using the existing angle. GPA a Move to a point specified by the angle, using the existing radius. GPRA da Move to a point specified by the current angle (da) value, using the existing radius. GPRR dr Move to a point specified by the current radius (dr), using the existing angle. GR Design grid setting, for example, GR 8-1/3, GR 25 25, G 25. GV Via grid setting, for example, GV 8-1/3, GV 25 25, or GV 25.
发表于 2003-12-4 12:51:52 | 显示全部楼层
G 虽然是Global的设置,但只适用于Design grid 和Via grid. GD 是设置Display grid.
GMT+8, 2025-5-17 02:27 , Processed in 0.121611 second(s), 20 queries .
