查看: 2192|回复: 25
ALLEGRO不能这样玩呀,怎么着也删不掉器件了!
发表于 2003-12-10 10:04:27 | 显示全部楼层 |阅读模式
发表于 2003-12-10 10:46:19 | 显示全部楼层
我可以删掉啊
为什么你不可以呢?
 楼主| 发表于 2003-12-10 10:53:59 | 显示全部楼层
我可以删掉除了BGA以外的其它器件,但是不能删除BGA。
而且如果删掉其它器件不存盘,再删BGA,其它器件又都冒出来了。
难道是ALLEGRO坏了?
发表于 2003-12-10 11:05:46 | 显示全部楼层
你試試先把周圍的via,線殺掉再殺零件﹐我這邊剛開始時也會出現像你說的那樣的提示﹐后來反孔和線殺掉后就可以了。
发表于 2003-12-10 11:54:55 | 显示全部楼层
我也可以删掉呀
发表于 2003-12-10 12:09:56 | 显示全部楼层
可发啊
发表于 2003-12-10 12:54:01 | 显示全部楼层
用“DB Doctor”跑一下试一下
再打开图
发表于 2003-12-10 13:05:43 | 显示全部楼层
狠一点,重装cadence!
发表于 2003-12-10 13:24:21 | 显示全部楼层
可以删除。
发表于 2003-12-10 13:38:50 | 显示全部楼层
Hi, Fang,
     I have check the brd file. I got the same error message as you.
     I have ran dbdoctor, but no error reported.
     But I still think this problem is resulted in by some database error.
     So I exported footprint, placement, and specctra session file, and then delete all things on the test6 board。 Finally I import the placement and session file again. Now the test7.brd is ok.
     It is so shameful to say that I could find what cause the problem. Just use it.
GMT+8, 2025-5-16 14:36 , Processed in 0.137191 second(s), 21 queries .
