查看: 1586|回复: 4
请教一个出网表问题!
发表于 2004-4-26 13:17:15 | 显示全部楼层 |阅读模式
请教一个出网表问题!
我在用ORCAD出Allegro的网表的时候遇到这样一个问题!网表出了不能和Allegro连接,是怎么回事呢!请问哪位大侠给个指点啊!view log 报的错在下面!我看不懂为什么啊!
C:\Cadence\PSD_14.2\tools\Capture\allegro.cfg
Spawning... "C:\Cadence\PSD_14.2\tools\Capture\pstswp.exe" -pst -d "d:\working\lvds_4u_reuse-v03_1\net\lvds_4u_v03.dsn" -n "D:\WORKING\LVDS_4U_REUSE-V03_1\NET" -c "C:\Cadence\PSD_14.2\tools\Capture\allegro.cfg" -v 3 #1 Warning [ALG0047] "No_connect" property on Pin "U14.24" ignored for U14: SCHEMATIC1, 5-CPU (3.00, 1.10). Connecting pin to net "ADDRESS7". #2 Warning [ALG0047] "No_connect" property on Pin "U14.27" ignored for U14: SCHEMATIC1, 5-CPU (3.00, 1.10). Connecting pin to net "ADDRESS4". #3 Warning [ALG0047] "No_connect" property on Pin "U14.26" ignored for U14: SCHEMATIC1, 5-CPU (3.00, 1.10). Connecting pin to net "ADDRESS5". #4 Warning [ALG0047] "No_connect" property on Pin "U14.25" ignored for U14: SCHEMATIC1, 5-CPU (3.00, 1.10). Connecting pin to net "ADDRESS6". #5 Warning [ALG0047] "No_connect" property on Pin "CONC2.C2" ignored for CONC2: SCHEMATIC1, 4-interface2 (3.10, 0.40). Connecting pin to net "LED_DR7". #6 Warning [ALG0047] "No_connect" property on Pin "CONC2.B2" ignored for CONC2: SCHEMATIC1, 4-interface2 (1.60, 0.40). Connecting pin to net "LED_DR6". #7 Warning [ALG0047] "No_connect" property on Pin "CONC2.A1" ignored for CONC2: SCHEMATIC1, 4-interface2 (0.20, 0.40). Connecting pin to net "LED_ DR0". ##115 Warning [ALG0051] Pin "VCC" is renamed to "VCC#8" after substituting illegal characters in Package EPCS1/4 , U6: SCHEMATIC1, 1-FPGA (4.80, 13.00). #116 Warning [ALG0051] Pin "VCC" is renamed to "VCC#7" after substituting illegal characters in Package EPCS1/4 , U6: SCHEMATIC1, 1-FPGA (4.80, 13.00).
Exiting... "C:\Cadence\PSD_14.2\tools\Capture\pstswp.exe" -pst -d "d:\working\lvds_4u_reuse-v03_1\net\lvds_4u_v03.dsn" -n "D:\WORKING\LVDS_4U_REUSE-V03_1\NET" -c "C:\Cadence\PSD_14.2\tools\Capture\allegro.cfg" -v 3
*** Done ***
******************************************************************************** * * Updating Allegro Board * ******************************************************************************** Netlist Directory: D:\WORKING\LVDS_4U_REUSE-V03_1\NET Input Allegro Board: D:\working\LVDS_4U_REUSE-V03_1\shiyan\shiyan.brd Output Allegro Board: D:\working\LVDS_4U_REUSE-V03_1\shiyan\shiyan1.brd
Spawning... netrev.exe -5 -y 1 -x -i "D:\WORKING\LVDS_4U_REUSE-V03_1\NET" "D:\working\LVDS_4U_REUSE-V03_1\shiyan\shiyan.brd" "D:\working\LVDS_4U_REUSE-V03_1\shiyan\shiyan1.brd" Reading File : D:/WORKING/LVDS_4U_REUSE-V03_1/NET/pstchip.dat (00:00:00.01) Reading File : D:/WORKING/LVDS_4U_REUSE-V03_1/NET/pstxprt.dat (00:00:00.04) Reading File : D:/WORKING/LVDS_4U_REUSE-V03_1/NET/pstxnet.dat (00:00:00.06) Starting to process component instances
netrev run on Apr 26 13:19:34 2004 DESIGN NAME : 'LVDS_4U_V03' PACKAGING ON Feb 7 2002 16:12:12
3 errors detected No oversight detected No warning detected
cpu time 0:00:46 elapsed time 0:00:00
Exiting... netrev.exe -5 -y 1 -x -i "D:\WORKING\LVDS_4U_REUSE-V03_1\NET" "D:\working\LVDS_4U_REUSE-V03_1\shiyan\shiyan.brd" "D:\working\LVDS_4U_REUSE-V03_1\shiyan\shiyan1.brd" Cadence Design Systems, Inc. netrev Mon Apr 26 13:19:34 2004 (C) Copyright 2002 Cadence Design Systems, Inc.
------ Directives ------
RIPUP_ETCH TRUE; RIPUP_SYMBOLS ALWAYS; MISSING SYMBOL AS ERROR FALSE; SCHEMATIC_DIRECTORY 'D:\WORKING\LVDS_4U_REUSE-V03_1\NET'; BOARD_DIRECTORY 'D:\working\LVDS_4U_REUSE-V03_1\shiyan'; OLD_BOARD_NAME 'D:\working\LVDS_4U_REUSE-V03_1\shiyan\shiyan.brd'; NEW_BOARD_NAME 'D:\working\LVDS_4U_REUSE-V03_1\shiyan\shiyan1.brd'; UPDATE_DEPTABLE FALSE;
CmdLine: netrev.exe -5 -y 1 -x -i D:\WORKING\LVDS_4U_REUSE-V03_1\NET D:\working\LVDS_4U_REUSE-V03_1\shiyan\shiyan.brd D:\working\LVDS_4U_REUSE-V03_1\shiyan\shiyan1.brd
------ Preparing to read pst files ------
Starting to read D:/WORKING/LVDS_4U_REUSE-V03_1/NET/pstchip.dat Finished reading D:/WORKING/LVDS_4U_REUSE-V03_1/NET/pstchip.dat (00:00:00.01) Starting to read D:/WORKING/LVDS_4U_REUSE-V03_1/NET/pstxprt.dat Finished reading D:/WORKING/LVDS_4U_REUSE-V03_1/NET/pstxprt.dat (00:00:00.04) Starting to read D:/WORKING/LVDS_4U_REUSE-V03_1/NET/pstxnet.dat Finished reading D:/WORKING/LVDS_4U_REUSE-V03_1/NET/pstxnet.dat (00:00:00.06)
------ Oversights/Warnings/Errors ------
#1 ERROR(302) Device library error detected.
Problems with device 'ICS502_SOP8\200_ICS502M'. JEDEC_TYPE property 'SOP8\200' is illegal: 'Package name is not legal.'.
Device 'ICS502_SOP8\200_ICS502M' has library errors. Unable to transfer to Allegro.
#2 ERROR(302) Device library error detected.
Problems with device 'CAP_0_CAP\5MM\R8_1000UF'. JEDEC_TYPE property 'CAP\5MM\R8' is illegal: 'Package name is not legal.'.
Device 'CAP_0_CAP\5MM\R8_1000UF' has library errors. Unable to transfer to Allegro.
------ Summary Statistics ------
#3 ERROR(102) Run stopped because errors were detected
COMPILE 'logic' CHECK_PIN_NAMES OFF CROSS_REFERENCE OFF FEEDBACK OFF INCREMENTAL OFF INTERFACE_TYPE PHYSICAL MAX_ERRORS 500 MERGE_MINIMUM 5 NET_NAME_CHARS '#%&()*+-./:=>?@[]^_`|' NET_NAME_LENGTH 24 OVERSIGHTS ON REPLACE_CHECK OFF SINGLE_NODE_NETS ON SPLIT_MINIMUM 0 SUPPRESS 20 WARNINGS ON
*** Done ***
发表于 2004-12-10 21:10:36 | 显示全部楼层
[em01][em01]不明白
发表于 2004-12-10 21:44:56 | 显示全部楼层
你定义的元件封装在allegro中没有
发表于 2004-12-17 15:18:00 | 显示全部楼层
device 中不能有\等非法字符
发表于 2004-12-27 23:00:42 | 显示全部楼层
封装起的名字有问题,修改一下名字试试
GMT+8, 2025-5-16 11:25 , Processed in 0.141978 second(s), 19 queries .
